New WoodChat!
Back to working wood ... dovetails!
It seems to me that there has been a lesser involvement with working wood in the past few weeks. So I present this for discussion. Hopefully :)
Strategy in dovetailing ...
http://www.inthewoodshop.com/Furniture/DovetailBaselines.html
What do you do?
Re: Back to working wood ... dovetails!
Mark Salomon
I don't find that I have as much of a problem with baselines as you seem to have Derek. First, the Titemark does fine marking the baseline for me as long as a bit of wood is also chiseled away/relieved from the baseline and I don't try to chop away too much--maybe sneaking up to about 1/16 of an inch or so before I actually commit the chisel to the baseline. Perhaps if I tried to take a more aggressive chop at the baseline I'd run into problems. This is not to say that there is anything wrong with your approach, it's just that I don't seem to have a problem in this area. Thanks for the ideas and the fodder for discussion!
Patrick Gibbons
I find the base lines of dovetails to be an ongoing problem. I think your method may solve a lot of my problems. Thanks for the submission.
Dean J in MN
I use a marking gauge to gauge the baselines, chop near*, but not on, to remove waste, and as a final cleanup drop the chisel into the baseline. Flip and repeat.
* "Near" -- how near depends on the wood in use, and how far your chisel drifts back in that wood (which can vary on wood, bevel angles, how you hold the chisel, etc. but a test whack or two shows this without fretting over things).
-Dean
a rabbet
rononkokomo
who is it that teaches planing a 1/16 deep rabbet to aid in accurately maytching tails to pins and also establishing a baseline?
Re: a rabbet
Cecil Nickerson in Halfmoon Bay
Rob Cosman for one.
Pam Niedermayer - Austin, TX
Looks like a good methodology; but I don't do the coping saw waste thing, simply chop and/or pare the waste, a la Klausz and Kingshott. I have thought about Cosmo's rebate treatment and tried a couple that way, but I'm not sure that it solves anything that using a Kinshiro doesn't solve.
Pam
Consider the Rob's approach
North of the Border
After taking a full day course from someone who is good at the Rob Cosman's method, I now largely use Rob's method - with the help of a fret saw, a shallow rabbet cut (skew plane e.g.), and chiseling. No test fit and bang! the tail and pin pieces come together tight (in most of the cases). I don't agree with some of the ways he does things for his business, but when it comes to dovetailing approach and efficiency, I can't find a more efficient way than his (after trying other methods (e.g. Frank Klaus's) covered in books or magazines). I use no jigs to help me pare to the baselines.
Here's how Rob does it: http://www.youtube.com/watch?v=xxIgNel0H_I
Disclaimer:I am not recommending or promoting any of his products (in fact I have none of his tools), but I suggest that people who have had difficulties of doing clean and accurate dovetails look into his method. You don't need to buy any of his products to use his method.
Re: Consider the Rob's approach
Hi
The thing about a fine rebate (rabbet) as a ledge to sit the pin board on the tail board is that it does not address the issue of the baseline.
