We value your privacy.
All this talk/interest of using diamond paste charged cast iron got me searching for what might be readily available... that would be ready to use out of the box. David Barnett talked of using this system for gravers (I didn't have so much as a clue as to what a "graver" even is/was ) Anyway, trying to help make this process as easy as possible for folks to really try out using cast iron... anyone else have sources to add to the list...?
Although I use them on my Raytech-Shaw faceting machine. The little GRS Quick-Change gravers fit right into the faceting handpiece, too, but other gravers, while I do have other jigs and handpieces, I just hold freehand most of the time.
For narrow or awkward woodworking tools, I use angle blocks or typical honing jigs if anything at all. Plenty of room for my hand on the swiveling elevator table. Just raise or lower until the tool makes contact.
Of course, you can just use them without any turntable at all.
Re: YASFCI, please add links as you find them... : *LINK*
Phil Smith
You can always make your own. Several years ago I tried using brake disc for the lap. With 1 micron diamond was too aggressive for me to reliably hone the backs of chisels. Did not have a fixed diamond stone at the time or any 0.5 micron diamond powder. Might work well with 0.5 micron powder.
Here is link to old post with picture of disc mounted on lathe.
I bought a 2X3 foot CI surface plate for a little less than that at an auction.That plate will only be 4.5X5.5 inches and have a hole in it to boot.
I really do think that someone could find a used tablesaw table and have it cut up for less than that.Why is everyone so dead set on NEW?
Go down to the nearest power tool repair shop and ask there.I`d be surprised if they didn`t have something you could use.If they don`t have it right then I`ll bet within the next few weeks something will come in.Make do with an old brake rotor in the mean time.
Iron 4th most abundant element in earth's crust *LINK*
David Barnett
Lots of it on the surface, too. I used to see at least one rusty, broken hunk of recyclable iron at curbside for the taking every weekend, even dead bench top table saws. It's just iron, for God's sake. It's everywhere.
You're right, Bob -- even dimensioned iron stock comes with a nice coating of rust. But if you've just gotta have new (and Bill's nice lapping plates are sold out), at least buy one of those ubiquitous cheap cast iron anvil-shaped-objects from your Chinese import tool store. HF has them now and then. They're not much good for anything else except holding things flat while the glue dries. I've seen the 55 lb ones for $39.95.
Re: Iron 4th most abundant element in earth's crus
Jim DeLaney, Austintown, Ohio
Tablesaw tops; tablesaw wings; jointer tables; bandsaw tables; some drillpress tables - they're all out there at you local used tool dealer or scrapyard. Maybe even laying in the dirt out behind your local used tool dealer's shop. Old cast iron is very common - you've just gotta be looking for it.
It's like the "Buy It Now" option at ebay... easy, dead easy.
I have my small cast iron discs for now, and will keep an eye out for something larger in the future and am sure I will run across something now that it's on my radar. If you want more folks to give diamond paste a "proper" look-see, they need to do it on cast iron, not MDF, ply, acrylic, vellum, etc.
An easy, dead easy... and if possible... cheap and easy to come by source with just a "mouse click-to-order-Buy-It-Now-style" option would make many horses out there... thirsty.
If you`re buying one of those ASOs(anvil shaped objects) for use as a combination weight and sharpening platform then go right ahead.Just don`t expect a cast iron ASO to function as an anvil.
CI cracks and breaks away when you hit it directly with a hammer.Those cast iron Fisher and Vulcan anvils they used to make had steel plates on the face and top of the horn to keep them from spalling,the edges from breaking and to give them some rebound.
An ASO only functions like a real anvil when used as garden art or dead weight.No hammering allowed!
I have access to 3 4,000 hp diesel engines (12 - 14 cylinder jobbies with pistons 18" across) that are being scrapped out. There must be SOMETHING in there that's usable.
You sent me on a nostalgic trip down Memory Lane, Bob, back to that delightful chestnut: Influence of Graphite Morphology and Matrix Structure on Chip Formation During Machining of Gray Cast Irons, (Marwanga, Voigt, Cohen -- 1999). Yes, it's all about the graphite. What makes CI so good for diamond lapping is what also makes it so bad for whacking.
While looking for the photo of my faceting machine, I came across another chestnut wherein I attempted to nutshell, rather poorly, this dual concept of fine-grained diamond grit capture and lubrication in a single sentence. It took Dan Donaldson all of five minutes to give me grief for my characteristic abstruse verbiage.
It's never too tough to tempt a guy who wears a trenchcoat and cut-off trouser legs tied below the knee to exhibit his proud possession. Wait for it. ... ... Ta-Daaa!
It's an old pic, though, and you'd see the difference now that the top is flat, polished, gleaming, with a satiny glow to the upper horn, as well. Wouldn't touch the rest of that patina --- not a chance.
Now it lives in my new home next to one of the jeweler's benches, in what used to be (and would still be for any normal person) the dining room. Slide the wall-o-glass into its pockets, wheel up the forge and have at it. Pool or jacuzzi slack tubs. Life is good.
Walnut, of course, to match the other shop furniture. Lap joints, butt joints, truss rods. Easy. How many times has someone informed me "you have an anvil in your house!" Which means, "I see you're not married!"
Mom always said "You can tell the caliber of a man by what he chooses to rest his tool on".I used to think my curly maple stump was hot stuff till I saw what David`s got.
I`m bettin` David doesn`t use a striker very often,although he may change his tune when he sees Scott`s open toed designer footwear.
Mom was always a practical sort of gal,she wore combat boots while swingin` a hammer.I always thought she looked pretty good in a leather apron though.
I`m told the elder `smiths considered her really hot stuff,despite her choice of footgear.
Me and my brothers paid for her choice in shoes out on the schoolyard though.
"How are you supposed to let your high dollar boxers show while wearing those? Anybody up for a chorus of 'Pants on the ground'?"
So you're gonna pop the top on that EZ-open can o' red wigglers, huh?
First, they simply don't make Hoodie-Footies in size-78, and they had to cut me out of the only Snuggie I ever tried on. As for high-dollar boxers? They don't make those in my size, either, so that had absolutely nothing to do with my so-called saggin' incident.
"That footie/hoodie is so out of step with fashion today."
We shouldn't be so quick to judge the occasional fashion faux pas, Bob. Besides, a real judge withheld adjudication pending community service in my case, as she believes I've learned my lesson.
You see, if it hadn't been for all the caffeine in those first dozen cans of Watermelon Four Loko, I might not've gone so overboard with my sister's BeDazzler. Do you have any idea how many stud-n-rhinestone refill kits it takes to BeDazzle size-78 britches and how much that weighs? Doesn't matter. I looked liked walkin' Las Vegas when I strolled into the Seminole Casino! If only they'd stayed up.
So while it's true I failed to adequately support those pants, those same pants are now supporting three families of undocumented recyclers in an Imokelee, Florida utility shed defestooning just that one pair -- enough to supply six post-Hurricane-Charlie FEMA-trailer parks and three more seasons of Toddlers & Tiaras.
Those tools aren`t real big up north.It can be down right dangerous to edge up to a wood stove for any amount of time with metal studs anywhere near your sensitive parts.
If they made an industrial version I might could use it to install studs on the wife`s tires though.
I did get one of those tools re-gifted to me a while back.How do you think all my toads became diamond studded?
I was working on something snarky in the union suit line when I got down here to your post.
I'm tempted to reflect on how ridiculous this would all look, but 20 years ago I'd have said the same thing about having 6" of boxers showing above one's low riders. Now why hasn't that trend caught on with plumbers?
We're going to have to get you guys your own guest slots on Project Runway
