Coupla diamond sharpening questions
Frank D. in Montreal
Hi everyone,
I searched the hand tools forum but can't seem to find an answer to my questions.
1. What's the best way to cut up an old cast TS top? I read about hacksaws...would a hand grinder with a cutoff wheel be OK?
2. I read that many who use cast iron have the surface blanchard ground. I'm not afraid of machine shops, but could I avoid this step and flatten 3 sections by rubbing them together with carborundum (I suspect coarse diamond would contaminate them and make them useless)?
3. I'm not sure I want to start honing all my blades by hand, simply because I have a sytem that lets me give a precise camber to blades by applying pressure at certain points of the blade for a certain number of strokes. I'd probably have to redo the math for the number of strokes, but I doubt I could get a half-thou camber by hand. Should I use a different sharpening jig for each diamond grit/plate? (I suspect yes)
Thanks
