Yost patternmakers vise mounting
Phil Smith
Anyone here have a Yost Patternmakers vise? I am looking for advise on mounting to the bench. Recently picked one of these up and curious how others have recessed the vise into their bench.
Phil Smith
Re: Yost patternmakers vise mounting *LINK*
James Watriss
I haven't mounted a Yost before, but I recently wrote up a bunch on installing my Emmert at the link below.
In short, if you want to recess, it's possible to do a nice inset mount, but I found it was a lot easier ultimately to cut out a square notch. The problem I ran into with the contoured inset mount was that I could match the contours of the vise when it was square, but that kind of arrangement didn't leave room for the vise to rotate. I tried carving out an arced version of the contour, but I had to chase that around because the beam isn't actually centered in the vise, so it took some doing to lay it all out. In the end, the point of a contoured inset was to make it look like a neat, clean install.. and once everything was carved out, it wasn't so neat and clean anymore. Then when I tried rotating the jaws when the vise was pivoted up at an angle, I realized that there was even more carving to do, because that contour needed to continue around the front edge of the bench. Really, it just needs to follow the barrel of the hinge on the mounting plate, but at that point, I was fed up, which led to the square notch.
The best advice I can give is to lay things out pretty close, but don't you dare lay out the three screws on top, or attempt to drill them. Thread the front jaw all the way out until it comes off, and focus on hanging only the rear jaw. Use the two holes on the back of the mounting bracket to do your initial mounting. Trim and shim the vise using only those two screws, until you get everything just right, and check against the front edge of the bench with a straight edge to make sure you're flush (if you want flush) or parallel. The official Emmert instructions say to mount so the jaw is 1/8" away from the front edge.. which makes sense. I'd rather make sure my work will clear the bench if I rotate the vise. If you want to clamp a long board to the front edge of the bench, you can make an L-shaped piece that will hang a 1/8" shim off the top edge of the bench, so you can clamp up.
Once the vise is in, and you've trimmed and shimmed the mounting point to get the rear jaw properly aligned, then lay out and drill the three holes on top. Those three will fix the vise alignment with regard to the front edge of the bench... which is why they should be saved for very last.
http://jameswatriss.blogspot.com/2010/10/finished-installation-and-final.html
Phil Smith
Thanks for the reply and link. I had previously found you blog and decide I was not interested in mounting the vise flush with the front edge of the bench.
"The official Emmert instructions say to mount so the jaw is 1/8" away from the front edge.. which makes sense. "
This is the piece of data I need. My guess is that the Yost will have the same clearance.
The Yost is deep enough that I did not have to carve out the bottom of the bench which simplifies installation. Have temporarily mounted the vise to the bench with about 1 inch of clearance from back of bench to vise.
See pictures.
