New WoodChat!
ADVERTISE HERE - FREE TRIAL
My Moxon dovetail vise
Joseph Moxon's twin-screw vise has been on my To Do/Must Have list ever since Chris Schwarz published his model and demonstrated its value as a dovetail vise in his column.
Chris' Moxon vise ...
Link: http://blog.woodworking-magazine.com/blog/Declaring+Victory+With+The+Doublescrew+Vise.aspx
It kept getting put aside, partly because it required making wooden screws, which I had not done before. I went so far as ordering a kit to make 1 1/2" diameter screws, and then it languished in a drawer for several months. Incidentally, I bought this from my local Carba-tec store. It looks the generic Chinese tap and die set.
It is not as though I could not use a vise such as this. In fact I needed this weeks ago when I began building a couple of military chests with many dovetails (carcases and drawers).
Inspiration came a few days ago I received an email from LN (Australia) asking me to be a co-presenter at their first workshop in Perth. This will involve dovetailing, so I decided to get off my butt and make a Moxon dovetail vise. At least I would have flash equipment ... :)
My thanks to Chris for his recent (December) article in Pop Wood.
What I have come up with has a little variation, not much, but enough to make this an exceptionally useful tool.
I built the screws out of some nondescript hardwood that I have no name for (but looks like a gum). It was all I had that was thick enough. Fortunately it all went well - it turned well, and did not chip when making the threads.
The screws are set 520mm (20 1/2") apart, but the total base is 840mm (33") long and 105mm (4 1/8") deep. The face is 110mm (4 1/4") high.
What's different?
The first item is that I have added "ears" to the sides of the base.
These make it easier to clamp to the bench top (than attaching it at the upper side of the vise, per se).
There is also a 75mm (3") wide rear support, which could be used with a holddown.
Of course the vise is simply to hold a board at a comfortable height for sawing. It does this very well. I was surprised how well the bare wooden faces hold the board. I was planning to add chamois leather, but thiis does not appear necessary.
Now in the background you can see what looks like a wooden "I-beam". It is ..
This was also just scrap, but turned out 370mm (14 1/2") long and 90mm (3 1/2") deep. It is sized to be 1/2" taller than the vise.
320 grit beltsander belt is attached on both sides. This provides anti-slip.
Stop using that handplan to rest the boards when transferring tails to pins! Use this rest instead ...
Raise the Pin Board 1/2" higher that the edge of the vise.
... and add the Tail Board.
But wait ... there is more!
I need to transfer the tails on a board that is too long to fit across my bench, and the bench is too narrow to clamp the board at the end (without resorting, as I usually need, to some Heath Robinson creation).
The Moxon vise has the length and the rigidity to provide a stable and secure hold on the boards while you transfer marks.
Clamped at one end ..
... and clamped at the front ...
You can also see the rest clamped to the edge of the bench, in line with the vise.
Now place the Tail Board on top ..
I was again surprised at the stability of the Tail Board which was only held down by its own weight. However, I recommend that one add clamps at each end.
Now you can tap it into perfect alignment, ready for knifing the lines.
Another view ...
Now back to dovetailing ...
Re: My Moxon dovetail vise
Jerry Gibbs
nice looking vise, but what is the advantage over a wide bench mounted tail vise?
bad backs
McKay
I only really need a twin screw when I dovetail, and with my bad back the height adjustment is just what I needed. I used this vice extensively in a recent class in traditional wood working. I tried to make the wood screws, but my attempt was futile. I used metal screws for pressing veneers. The vice works great and when not in use it sits out of the way with all of the other jigs.
Jack Guzman from Maine
Derek,
I saw one similar to that in the workbench book. I copied it in of red oak. Yours is a lot nicer though and I like that Ibeam fixture. Thanks for posting.---Jack
Hi Jack
I found it. There's a modified bookbinder vise that looks very similar on page 134 of Scott Landis' book.
Great minds ... (Moxon, Schwarz, Cohen and a thousand others)
Nice!  and timely...
Tony - Memphis
This is on my to do list right now. I have a nice piece of hard maple left from another project. I also have some makore left from a project that will make nice handles. Thanks for the good ideas. I haven't mastered my threader yet. I've gotten some decent results, but I still have some learning/tweaking to do.
Thanks for posting.
Tony
your looks more galootish
roninkokomo
I made one several years ago, but I cheated and used t nuts and 1/2 inch threaded rod. The inside fence is an L shape and I hold it to the bench top with clamps or hold fasts. Fences are hard maple 2 in think One of the very most useful fixtures in my shop. Would not think of cuttin dovetails without it
Well done!
Scott Burr in Ben Lomond CA
One of these is on my todo list as well. Thanks for posting you version. I like the design of it. Lots of tidbits for me to steal. :D
