New WoodChat!
Knew Concepts Fretsaw - updated review
Re: Knew Concepts Fretsaw - updated review
TomD
That's cool. Another fancy tool!
I just put the blades in backwards and tweak them 45 degrees, never lost a lee valley blade. This allows me to use a pretty small saw with nice balance. For the tails, on drawers and such they can be cut with a power fret saw.
Scott in Montana
Derek,
Thanks for another high quality review.
I do have a question. Is the handle size as annoyingly small as that of my old Olson saw? I currently wrap mine with hockey stick tape as suggested by Rob Cosman as to increase the diameter and therefore better fit my hand. But it just looks so ugly in my tool cabinet.
Scott in Montana
Hi Scott
The handle size is about the same as the Olson.
I don't have a problem with this, and my hand is quite broad (I am told), measuring 100mm across. In fact, my jeweller's saw handle is slimmer.
bugbear
Time to google Tsuka-maki (sometimes Tsukamaki)
BugBear
bugbear
Cam tensioning, you say?
http://toolemera.com/pampdf/the_art_of_fretwork.pdf
P11, fig 4
Ain't nothun' new under the sun
(Except titanium fret saws!)
BugBear
Nuthin', BB, except a design that creates a rigid frame, a taut blade, and a managable tool .... as opposed to a springy, twisty, banana. :)
Nice find on the book, nevertheless! Your encyclopaedic recall never ceases to amaze me!
bugbear
Does the fact that I own 3 of those fretsaws (14", 16" and 18") reduce the amazement?
BugBear (cheating on a memory test)
Or, if you're feeling less ambitious,
you can get a rubbery plastic compound in cans - dries to a texture very similar to the rubbery grips you find on some power tools. While each individual layer's pretty thin, I bet you could build it up to a fairly impressive thickness by repeated dipping/drying cycles.
Warning: if you get one of those cans, look around the shop for handles to cover. Once you open the can, it starts drying out, and a can full of hardened rubbery plastic has limited uses in the shop.
