looking for a reamer
McKay
I am looking for a reamer of about 10 deg. that would allow me to ream out a taper for chair legs. Thanks in advance for any directions as to where to look.
McKay
Re: looking for a reamer
Lee Valley offers a couple of them with 12.8 degree tapers. Go to their site (through the link at the marketplace, so Ellis can get some advertising money if you buy) and search on "chair reamer."
I don't know, but...
Scott Burr in Ben Lomond CA
I have one from MSC. It requires about a 1/2" hole to get it going.
Yes, I'm talking about a drill press applied tool.
It cuts very smooth holes.
bugbear
Apols for partial memory; but...
"someone" on "a forum" posted a success story of making their own - it was a tapered wooden body with an inserted blade. I can't remember much more.
BugBear
Bob Rozaieski
I made my own using an old saw blade. Jennie Alexander has plans on how to make it.
Adam Cherubini
When I first started reaming holes, I thought the reamer would somehow follow the hole. Oh no no no. The reamer is a new operation and cares nothing about the parent hole. For accurate (concentric reams) you may do just as well with a free hand line drawn around your hole and a rasp or carving gouge. For windsor chair type seat joints, I don't think having a perfectly round hole is a neccessity.
One more thing, I could be wrong, but I suspect alot of the larger, famous Windsor chair makers aren't doing their holes (or the reaming) by hand. With a hand reamer, if the bit isn't blazingly sharp, it cuts where the wood is easy to cut and not where it's not. I've had trouble maintaining the correct angles with my reamers. I suspect period chair makers used breast bibs and a lot of experience to do this quickly and easily. It may not be so easy for the rest of us.
Adam
Bob Rozaieski
I made my own based on a design by Jennie Alexander. The blade is basically a scraper and is just made from an old hand saw blade. It works really well. Curtis Buchannan uses a similar one. You don't even need to remove the old saw teeth.
The design can be found here:
http://www.greenwoodworking.com/SawSteelTaperedReamerPlans
Re: looking for a reamer *LINK*
Pam Niedermayer - Austin, TX
May be John Alexander, Green Woodworking, is who you're thinking of.
TomD
I would agree to the degree that it is often better to steer it. So the normal practice is to start reaming, step back and gage it, then steer it in the direction it needs to go. I mostly use either the Alexander sawblade reamer, which seems to work better than others. Or that one made by that machinist fella in NY, or some LV ones, meaning I don't spend much time with the traditional ones that look a little like a spoon bit. Is that the type you are struggling with?
I would add that leaving the teeth on the Alexander one makes it cut faster. I made mine while out of the shop with just hand tools, so don't be put off if you don't have a lathe.
Re: thanks
bugbear
That's certainly the design I remember, but I'm sure what I saw was a forum post.
No matter.
BugBear
Probably not the first time I've posted it.
