New WoodChat!
Plaque for grandpa's anvil
Moses Yoder
Moses Yoder
One of the departments in the company I work for has a laser engraver that can engrave brass plaques. I want to get a 3" x 5" plaque made to put on the stump that came with my grandpa's anvil that the anvil sets on. My problem is a brain fart I guess; I am not much of a word smith. I can't figure out what I want on the plaque. If I say "Former property of Christian C. Yoder" and the years he lived underneath I am not happy with the sound of it. If I just say "Property of" it's not true because it no longer belongs to him. If I say "In Memory of" it doesn't really indicate that it was his anvil. I'm looking to you to brainstorm a bunch of ideas then perhaps I can pick one that I think sounds good. I think it will be pretty meaningful as the anvil gets passed on down to future generations. I had to pay for the anvil but I plan on giving it to someone in the next generation, perhaps a future son-in-law.
Re: Plaque for grandpa's anvil
John Aniano in central NJ
How about
Working Anvil of Christian C. Yoder
18??-19??
and just have the text centered on the plaque?
Marv
Moses,
To help you think through it so the words will be yours, try to think of what you would want on a plaque if the anvil was yours and it belongs to one of your grandchildren.
Marv
Pam Niedermayer - Austin, TX
The property is still property, it's the grandfather who's former; so your first cut will be a puzzler.
I like John's suggestion a lot.
Pam
Frank D. in Montreal
Hi Moses,
I'd just put "This anvil belonged to... (18..-19..)" You could leave out the years of birth and death if you really want it simple, but it does serve as a good reference for future generations.
Re: What's the point?
TomD
Is the plaque about the anvil or about the person?
"Working Anvil of Christian C. Yoder
18??-19?? "
Sounds more anvil related to me. The anvil is the subject. Also there is an implication that the lifespan and working span are the same, though obviously not.
An alternative would be:
Christian C. Yoder
18??-19??
This would be memorial form, so the dates match his lifespan, and one would not assume they were the period he used the anvil
Christian C. Yoder
18??-19??
Held the Hammer
This is a symbolic statement, symbolizing both his time as a blacksmith, and his way of life, so the date order is reversed
Christina C Yoder
Blacksmith
18??-19??
Was he a Blacksmith, hobbyist? If he really was a blacksmith then the above date order is fine. If he was a lot more than that I would put the date order as in the example above.
Christian C. Yoder
Husband and Father
18??-19??
etc....
Think of what you actually want to convey. How that relates to this object.
Moses Yoder
Thank you all!
Moses Yoder
I think the thing we are trying to pass on in the objects our children inherit is a sense of roots attached to the past. I also thought about guessing his working years and just putting those on but I think the truth is that the anvil stands as a symbol of the man thus his entire life span will be remembered. My grandfather did some horse shoing but mainly he repaired buggys; he was Amish. He put a lot of steel rims on buggy wheels and used the forge and anvil to weld the ends of the rims together, making the rim the right size to fit on the wheel. They owned 40 acres and raised a large family subsisting off the 40 acres and the buggy shop. I like the "Working anvil of" phrase and I think will probably use that.
