New WoodChat!
200+ woodworking book reviews
QSWO cross: 2 things that are easier than I though *LINK*
wilbur
A friend of mine asked me if I could make a cross that would hang on the wall for him. After considering a couple of design options, I thought making a simple cross, 18" high, out of QSWO with the horizontal piece sitting a little proud of the vertical piece would be a good design.
Al Navas helped me with thinking about some of the details, and he generously sent me some QSWO that he had as a gift. I am so grateful to him for doing so. Thanks, Al!
So here it is. The joinery is not real sophisticated -- it's a simple lap joint, but the joinery and final prep of the surface was done completely with hand tools.
The two things that were way easier than I thought it would be were fuming the oak with ammonia, and making shellac from scratch for the finish. For the fuming, I used regular household ammonia in a tub (by the way, the bottle may say "lemon scented", but it still smells like ammonia), and built a quick and dirty frame to hold the cross above the tub. The whole setup was stuck inside a contractors garbage bag. I rolled up the opening of the bag, and put a chunk of wood on it to keep it from opening, and left it in there for 2 days. The color change was clearly visible after just being in the bag overnight, and was quite dramatic after 24 hours.
The shellac I used was seedlac from shellac.net. It was a simple matter of making a 1 lb. cut by mixing 1 oz. of the seedlac in 190 proof Everclear, letting it sit overnight, and straining it through some cheesecloth. I used a rolled up old t-shirt material to pad it on. The shellac dries so fast I got about 5 coats on in 15 minutes. Then I rubbed some paste wax onto the cross.
I have more info about the Everclear and the seedlac on my blog.
By the way, all the hand work was done with Japanese tools, which are not supposed to be used with ring porous hardwoods like white oak, as we all know. ;)
Using Everclear for shellac
Re: QSWO cross: 2 things that are easier than I though *LINK*
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Hi Wilbur,
This is a wonderful way to learn how to use your tools and also a classic finishing technique. Thank you for sharing your path and also feedback on your learning. I am inspired to try the fuming process on my current project.
Take care,
Jim
Very nice
Sometimes simple is the most effective.
Good to hear about the fuming - some authors make it sound very complex and insist on industrial ammonia, then warning about how hazardous it is. It's good to know the household stuff will work, at least for small pieces.
The picture makes it look a little yellow on my computer - probably not due to the lemon scent...
Household ammonia and yellowness
wilbur
The yellowness is due to CFL bulbs in my kitchen, and awesomely crappy white balancing with my 4 year old point and shoot digital camera.
As to the household vs. industrial ammonia issue, I read those reports on the internet, and recalled using aqueous ammonia in chemistry lab in college (I was a chem major) and my first thought was, "There's no way that stuff is coming into my house!" That's the sort of stuff I would only use in a hood.
All the aqueous ammonia will do is speed up the process and cause damage to your corneas. It's a chemical reaction that causes the color change, so even though this is the first time I tried this, I think I remember enough chemistry to predict what would happen.
If you have time to let the workpiece sit and bathe in the ammonia, the household ammonia should be fine.
If you need to impart a color change in an hour, then you'll need the industrial stuff.
If you have a large piece, the household ammonia should be fine. You'll just need a chamber big enough to house it, and time.
Two other things that I think helped: First, a low flat container is better for allowing the ammonia to fume out. That's what I used. Think baking dish, not pasta sauce jar.
Second, I bought the jug of ammonia the day that I used it. At less than $1.50 for a 32 oz. bottle, I don't see any reason not to use ammonia fresh out of the bottle. I saved the ammonia that I used, but next time it might take a little longer to fume a piece.
Re: Household ammonia and yellowness
wilbur
Correction: it's less than $1.50 for a 64 oz. bottle.
David Barnett
Cheaper than bad Camembert, pricier than cat pee
David Barnett
Bob Entwisle in NJ
Nice job on the cross, Wilbur.
Great results from the fuming.
Having some familiarity with the heavy duty ammonia we used to use in the blueprint machines at work, I have been as reluctant as you to bring that industrial strength stuff into the house for woodworking. But now that I see the household ammonia fuming results I'm going to have to give that a try.
Thanks (NOT!!!) for moving fuming off the not gonna try it list and back onto the incredibly long list of stuff I want to try. :D
Bob in NJ
Real picture with better white balance/color
wilbur
I brought the cross over and hung it on the wall of our friends' house.
Here's another photo with better white balance and color accuracy.
Fuming does create such nice colors
more easily seen in that picture. Thanks for the followup, Wilbur.
Re: Real picture with better white balance/color
Pam Niedermayer - Austin, TX
In this photo the grain makes it look like the stile is raised, which, while it is off center, looks very attractive. Not that I'd ever build a cross as such, but if I did, I think I'd incorporate a muntin type feature of a rise in the center of both pieces.
Pam
Wilbur mentions, back in his original post,
that the cross-beam is slightly proud of the post.
Re: Wilbur mentions, back in his original post,
Yes, but I'm suggesting that a triangular shape on top of both stile and cross pieces, meeting at the joint, would be more interesting. Kind of the way muntins are often shaped. Not a huge deal.
Pam
wilbur
I had thought about that design, and made a prototype, but this design is what my friends liked better. I liked it better too, given that I knew that I wanted to use QSWO for this project. I thought the rectangular shapes and the QSWO led to more of an Arts and Crafts feel.
For a muntin-ish cross, I think I would have gone for cherry or walnut -- something with grain and figure, but not as strong of a grain pattern as QSWO. To my mind, simple shapes support stronger grain patterns, and vice-versa. But that's just me.
And there you go.:) I do like the fumed oak a lot.
