Bevel angles in high angle BD plane
Dave Mount
Hello all -- been a while since I posted, but I've been around in lurk mode.
I bought one of the Lee Valley woodie replacement plane irons (3/16" thick, no cap iron) with the idea of making a fairly high angle (like 55 degrees) bevel down wood smoother for cleaning up difficult grain. It isn't as though there is no other way to accomplish the task, it was just a combination of a need and an excuse to build a new plane instead of doing other things that are higher on the "ought to do" scale but lower on the amusement scale.
Right after I ordered the iron, there was a snippet of discussion here about whether cap irons helped stabilize the cutting edge of thick irons. As I recall, there was not uniform agreement as to whether they did or didn't. As I understood the "camps", folks that thought that cap irons help even on thick blades argued that out at the cutting edge the projecting angle of steel is the same as in a thin iron, and that a cap iron therefore helped support even thick irons. Others thought that the greater mass back from the cutting edge still helped to stabilize the cutting edge.
Regardless of which view is most correct (I'm suspecting the truth may be in the middle), it got me thinking about whether, in the absence of a cap iron, there would be benefit to increasing the bevel angle in a high angle bevel down plane like the one I'm contemplating. The theory would be that doing so would put more metal closer to the cutting edge and avoid having it cantilevered as far out in front of the bed. Even if you went as high as 40 degrees on the bevel, there would still be 15 degrees of clearance, which is plenty as I understand it.
Does this make any sense and/or is there some other factor which comes into play that negates whatever benefit might come from a steeper bevel? Is a 40 degree bevel any less "sharp" if it is honed to the same extent a shallower bevel is?
Best,
Dave
