Works for me *LINK*
David Barnett
I've been corresponding with another diamond aficionado about loose diamond grit and how to compound it.
Firstly, yes -- diamond powder is cheaper and does allow one to adapt the vehicle to the application, which is what I do. Mixing your own compound is simple. But let me tell you about changes in compounding over the last few years.
Olive oil has been the traditional vehicle for most of industrial diamond's history. Diamond was graded by timed settlings in olive oil according to particle masses and measured oil viscosities. Originally, and until recently, diamond grit compound (or paste) used olive oil paste, a byproduct of olive oil distillation. In the last two decades, distillation has been entirely supplanted by the much more efficient, cost-effective and cleaner centrifugal technologies. As a result, olive oil paste, once a cheap and plentiful commodity, has virtually disappeared and is for all practical purposes extinct. Mind you, you can Google olive oil paste, but will find ozonated paste used for it's claimed rejuvenating properties. In fact, the oil fractions used widely in cosmetics are now cold-extracted and have no use as a diamond vehicle.
When I began gem carving, I used olive oil paste as described by Henry Hunt's "Lapidary Carving for Creative Jewelry", 1980, 1993. He says, in the section on Mixing Diamond Compound:
"The virtues of olive oil paste ... has a very high melting point, does not get rancid, is virtually odorless and is not greasy. it is the product of an industrial process involving considerable heat and pressure, and is not in the do-it-yourself class."
When he originally wrote this, diamond powder and compound suppliers sold olive oil paste in syringes for mixing with diamond powder. By the time Henry published "American Lapidary -- designing the carved gemstone" in 1996, he notes that with the disappearance of olive oil paste, carvers making their own higher-concentration compounds generally used Vaseline or floor wax.
"Both of these have serious drawbacks. They liquify at low temperatures, the wax is sticky and cakes when it begins to dry out, and both have an oily and slippery aspect."
"There is a much better solution. You want to obtain a pound of china clay from a ceramics supply store. It costs about a dollar and is enough for the rest of your life. It is a very fine kaolin clay used for making slips and glazes and other things that potters do. You can mix it with Vaseline to make a dry, thick compound, somewhat like toothpaste. To do so empty a small jar of Vaseline into a bowl and start adding powdered clay until all the oiliness disappears. Stir and stir. Now add a little more Vaseline until just a touch of oiliness reappears. Stir this thoroughly, and tthen store in the empty Vaseline jar."
His mixing instructions:
"To make this compound, spoon out what you need into a small container and add the diamond powder. I use one carat of diamond powder for each gram of compound, and usually mix 3 to 4 grams at a time. I use small 4 to 6 gram cosmetic jars to keep each size compound. The compound and diamond powder needs to be thoroughly mixed, lots of stirring, and always start with the finest and work down in order to avoid contamination. The china clay is usually a buff color that turns to a medium brown when mixed with the Vaseline. If you can get a pure white clay, do so. It keeps the surface of the work piece more visible. This material is just as good as the olive oil paste."
Understand that Henry's proportions yield compounds in the medium-high to high concentrations as far as honing goes, which is fine as long as you realize how little you need to charge and maintain your laps. You can certainly use less diamond to make it easier to spread and distribute, and I would recommend this, at least at first.
He goes on to say that he mixes it with as much as 3 carats per gram to speed things up when carving, which is about the concentration I use, nowadays.
I should add that a very well-known lap manufacturer to the faceting industry told me that one producer of top grade diamond compound admits they use hydrolyzed vegetable oil, Crisco, as a main component.
Until yesterday (I kid you not), I had used my dwindling supply of olive oil paste with hardly a thought to replenishment -- I had no idea it had all but disappeared -- but having been asked in private mail about this very subject, I quickly discovered its current scarcity, so reprised Henry's '96 writings on the subject, tried it last night and can say it does indeed perform as he states. I will also say, however, that I prefer the older olive oil paste on hand laps, but enjoy the newer paste on my rotary points and may even grow to like it better.
As for which china clay to use, I'm using Axner's New Zealand kaolin, described as: "From New Zealand China Clays, for use in highest quality tableware where exceptional whiteness and translucency are demanded. Extremely low Fe2O3 & TiO2." I'm sure most any finely ground china clay will suffice, however.
It sells for $2.03/lb, which is a lifetime's supply, but if you actually need more for whatever purpose, it's $1.17 for 5 lbs.
I used Vaseline last evening, but today I'm using a heavier petroleum jelly with a small amount of microcrystalline wax and damar resin.
