New WoodChat!
Have a question? Ask Woody!
moxon dovetail vice
moxon dovetail vice
moxon dovetail vice
McKay
I have a real problem with back muscle spasms. Cutting dovetails usually means that I cut one side, go into the house and put ice on the back. I saw this in PW and decided to take a chance on it helping. I not only am able to cut dovetails w/o bending over, but I saved money by not buying a twin screw vice for my bench. Double win I think. I would rather have a leg vice anyway.
Has anyone used the Hovatar leg vice? I would like to add this or someother leg vice. I do have a large screw that I could make one, but again, I do not want to have to bend down to move the bottom of the leg vice.
Re: moxon dovetail vice
Re: moxon dovetail vice *LINK*
Bruce, a MN Galoot
I've never heard of the "Hovatar leg vice." However, I like the solution you've pictured.
Something just occurred to me, though. I am the lucky recipient of back spasms, too, and never know when they're going to strike; bending over isn't all that much fun. How about one of those chain-driven vises that LV sells, and have it situated vertically instead of the other way? Mount it on the yonder leg and pretend it's a regular leg vise. You'd never have to bend over again.
Veritas Twin-Screw Vise
Scott Burr in Ben Lomond CA
I've never heard of a Hovatar leg vise. But, I remember seeing a leg vise with a steel "X" attached to the bench and leg vice face. Picture a scissor jack mounted vertically. I think it was the workbench book.
Nice job on the vise BTW.
Moses Yoder
Moses Yoder
I am not sure I understand why people don't want a shoulder vice but are building jigs on their bench that pretty much clamp wood in exactly the same position. Just my opinion. A shoulder vice is a little harder to build but when done even with fairly sloppy joints is still a strong vice and holds wood firmly.
no bending over to cut
McKay
Also when planing long boards,
Chuck Nickerson
a shoulder vise is something to dodge the last couple of feet.
For me, the bench front with no protrusions is less painful.
Weightlifter belt
Al Goldstein
I too have a bad back. Whenever I have to bend over for a long time I put on a weightlifter's belt. Its broad leather back not only supports but also traps heat that prevents my back muscles from going into spasms. Works for me I hope that it will work for you.
Gary Roberts
In days gone by this was sometimes called a St. Peters Cross. Those I've seen looked like what was found in coach builders, wheelwrights and patternmakers shops. Typically, the mouth of the vise was raised a good 6-10 inches above bench level.
I sold one at auction a few months ago that had the top just 6 inches above bench height.
Gary
