New WoodChat!
Dovetail Marker/Saddle Recommendation
Todd Nebel
I have this small brass dovetail marker in the ratios of 1:5 and 1:8.
I find it difficult to hold steady when marking and I would like other ratios. I would appreciate some recommendations on types and prices. I think I like the individual brass saddle types I've seen in background photos here, but I can't seem to find them at the usual online merchants.
Thanks in advance.
Todd
Re: Dovetail Marker/Saddle Recommendation
That's because Derek Cohen made them *LINK*
Bruce, a MN Galoot
and they're pretty nice, too. Take a gander at his tools.
I have the LV saddle marker, the one with the 1:6 ratio. I've found that angle works well in the stuff I dovetail, mostly drawers and boxes, made from wood between 1/2" and 3/4" thick.
"In The Woodshop" shop-made tools
David Barnett
Cheap solution *LINK*
David Barnett
I've made a couple from 1 3/4" 6063 T52 aluminum angle, which has a sharp inside corner, unlike 6061, which is rounded. Gave those away and made another set of brass, like Derek. Easy, quick, enjoyable. Hacksaw and a file.
You should have little trouble finding a piece of 1 1/2 x 1 1/2" to 2 x 2" scrap from a local metals recycler or hardware store. Failing that, there's eBay, of course, or OnlineMetals.com.
If you want the prettier and harder but pricier brass angle:
http://tinyurl.com/253tcxc
And there's aluminum or wood frame moulding, acrylic box corners, and so on. Now Derek's infill marker; not so easy, not so quick, not so cheap -- whole 'nother story.
Aluminum runs $2.68 for one foot.
If you don't want to make your own  *LINK*
Lee Valley's offerings are similar
Re: If you don't want to make your own
Todd Nebel
Hi Bill,
What's the verdit on the Veritas ones? Anyone like / dislike them?
Anyone like Woodjoy's? *LINK*
Todd Nebel
Anyone have one of the these from Woodjoy?
- Precision Dovetail Template
- Dovetail Saddle Square
- Double Dovetail Square
http://www.woodjoytools.com/page9/page9.html
Bruce, a MN Galoot
I have the Veritas 1:6 saddle gauge and like it a lot.
Jack Guzman from Maine
Lee Valley's are probably your best bet. You really shouldn't spend alot on a dovetail marker. You can do the job in many ways.Frank Klaus doesn't use anything. He just eyeballs the angle. I have a drawer full of different styles. I seem to be leaving them in the drawer alot more and just using a bevel. Just my opinion. I'm no expert.---Jack
George in snowy Lowell, Mich.
Todd,
I had the same problem with the one shown by the penny. I took a small piece of aluminium and made a longer "fence". It's much easier to hold.
George
Re: Dovetail Marker/Saddle Recommendation *LINK*
charlie belden
One of the shortcomings of most dovetail marking devices is that they only let you mark one face or end. A "saddle" marking gauge gets around that shortcoming. But even a "saddle" gauge has a shortcoming - it's opaque.
Here's one you can make that uses the "saddle" idea - and is transparent - so you can SEE where you are.
Transparent Dovetail Gauge
Thanks for all the feedback.
Todd Nebel
I think I'll try to make my own set of saddles in the future.
Phil Joines
If you have access to a sheet metal break you can bend them from 1/8" Polycarb.
Yes, but...
James Watriss
Yep.
I have their double dovetail square, and the total square. It makes a nice enough set, and they work well. I don't like the dovetail layout gauge, with the pin shaped holes... but they've been making those for a while, so maybe that's just my own preference.
After doing this for a few years, I find the tool I usually reach for is a sliding bevel gauge for dovetail layout. I do like Derek's little saddle layout tools, though.
