Completed Halfback saws
Dominic in Buck's County PA
Hi Gang,
Well it's been a while since I last posted an update to this project. I had ruined 3 or 4 handles right in a row and had allowed this project to languish for several months. After a pep talk from my assorted mentors (Klaus, Pedder, Jack & Marv W) I decided it was time to try again.
One thing I should mention is that I started out with three halfback saws but finished only two. The formed spine turned out to be less than perfect and caused the saw plate to kink. So I ditched it. I will probably order a formed spine from Mike W, or make another slit spine once my buddy gets him milling machine set up (friend gloat!)
As you can guess, my main problem were the handles. First it was getting a nice straight saw slot, then it was mortising in for the spine. Once I actually got it all right only to have the handle crack while I was putting the saw together (there is a reason you don't see saw handles made from Gonsalo Alves!).
First off, let's take a look at the problems I had sawing the slot. Hopefully someone can learn something from my MANY mistakes! These are two new handles totally made from scratch. One was apple, and the other is walnut.
One of the jewels Klaus passed along was how to improve my chances of sawing a straight slot. I usually saw the slots by blocking up my back saw with an appropriately sized piece of wood. Then I secure it to the bench with some holdfasts. Well, Klaus' tip was to only allow about 3/8" of the saw plate to extend from the "block". That way it was better supported and would not deflect. Thus giving me a nice start on the cut.
After the cut was established, I switched to holding the handle in my vice and continued to carefully deepen the cut.
After that was completed I followed up by using the saw plate destined for this handle to finish the cut. This ensured a perfect fit.
And all that careful preparation paid off! I ended up with a perfect saw slot in both handles. After that I mortised in for the spine (for some reason I have no photos of that.) and then moved onto drilling the holes and then shaping the handles.
These handles were a bit more complex than the open handled dovetail and carcass saw handles I've made. These called for some carving at the lamb's tongue. Something I have never done before. But some layout work with a sharp exacto, and some careful use of a 3/8" fishtail chisel I got from John Payne allowed me to pull this off.
After that was completed I used the chisel to clean up as much of the edges as possible, and went to work with a rasp to shape the handles. Once I was done with the rasp, I went to work with my scrapers to remove what was left of the template paper as well as the rasp marks
After that I spent some time sanding up to 200 - 300 grit.
I'd like to point out one set of clamps I use that had proven to be invaluable when shaping handles. These are el-cheapo 10" wooden clamps I got from HF about 12 years ago. One clamp is held on the bench by hold fasts, while the other is held upright by that clamp. I recently added a set of padded leather jaws to each and have been amazed at how much better they perform. I also added a set of 1/2" thick spacers under the bottom clamp to lift it up away from the bench top so I can grip the handles better. That way I can tighten and loosen the bottom clamp easier.
Now that the handles were sanded, it was time to transfer the holes to the saw plates, drill the holes and test the fit. Here I am transferring the hole location using a transfer punch I got from HF.
Since I had done it before, drilling the holes was easier this time. I spot annealed the locations and drilled them at low speed, being sure to quench the bit frequently with WD-40. I also got to use my new Drill Doctor to touch up the bits after each session. That is one power tool purchase I don't regret!
Now that the saw plates were set, it was time to apply a finish to the handles. Like the split nut driver I just made, I decided to use TruOil for the finish. I applied the first of three coats and allowed both handles to dry overnight.
The next night I buffed out the finish with synthetic steelwool (looks like a fine gray scotch brite) cleaned the handle off and re-applied the TruOil. I repeated this once more for a total of three coats. After that I buffed out the finish with 000 steel wool and wax followed by buffing at a Beall Buffing Wheel (Tripoli/White Diamond/Wax). And I got a super gloss finish! Dang, I really love this TruOil!
Tonight was the moment of truth. I cleaned up the saw plates and then assembled the saws. After all that hard work they went together flawlessly. And without further ado here they are.
I will probably sharpen them some time this weekend and then give them a test run. Look for more photos soon.
See ya around,
Dominic
