New WoodChat!
Have a question? Ask Woody!
A nice little drawer
I completed the drawer for the end table in process. It is a little drawer in a little table.
I put together a pictorial for those interested in making a London-style half-blind dovetailed drawer: http://www.inthewoodshop.com/Furniture/Londonhalf-blinddovetaileddrawer.html
This is the current state of the build. I should complete it tomorrow (the ply is just reinforcing while glue dries).
Re: A nice little drawer
Looks good, Derek
Andrew F in Australia
Hi Derek,
Looks good, as usual. Well done - great work.
Don't take the following as criticism, because it isn't intended or written with that in mind in the slightest (I've got no critical bone in my body,) but a few points that I noted:
You might want to consider mentioning in the tutorial that when you lay out the pins from the tails by marking with a saw, the saw kerf marks are left behind when you mark dovetails this way. If I was a novice reading this, I'd cut in the kerf marks and have a gap the width of the saw blade left behind.
The Karri pine has the WA spelling of the eucalypt, an understandable error, given you use it frequently - Kauri pine perhaps (Agathis sp...?) is the only one I'm aware of.
Normally, drawers aren't made until the opening is made, but I know with your level of detail in your work, the drawer opening/slides/kickers/runners will fit well.
The drawer slips/grooving is well done - Just as a professional point, the screw being headed across the grain looked incongruous - It looks more appealing if it's headed in the same direction as the grain, but does nothing to assist strength. The screw hole at the back isn't normally enlarged, but just a normal screw hole - the timber expansion happens in the groove at the front that you've mentioned in the tutorial. If you made this with timber from the mill, it's already at maximum moisture content, so the drawer bottom will shrink a bit anyway.
Cheers,
Andrew F
I'm impressed
Todd Nebel
Very nice work and I liked the pictorial series a lot. Thanks.
Patrick Gibbons
You've got skills. Both design-wise and in workmanship.
Thanks Patrick. I think that if I can do it then anyone can.
A little progress ...
The lay up for the table top is resting against the bandsaw.
I gotta say...
Bob Hackett
I`m liking the table made from those curved panels a whole lot more than I was liking the panels as corners on an entertainment center.
Really nice work and I love the design.It seems like it would be very user friendly if enlarged and made into a desk.
How come my re-work never comes out looking that good?
