OT - condensation on sheet foam insulation
We're preparing to insulate the cathedral ceiling of our shed conversion with 3" of polyiso sheet foam. Each rafter bay will be ventilated with a large soffit vent and continuous ridge vent.
Polyiso foam comes standard with aluminum foil on each face. Our son has heard from some roofers he's talked with that this construction detail creates problems with condensation on the upper face of the foam, running down to the lower edge where it drips off to start rotting the wall.
Is this in fact an issue? A local supply house can get me tarpaper-faced polyiso, but this doesn't serve as a vapor barrier (may not be an issue anyway; I will probably install a vapor barrier or use vapor barrier primer).
