New WoodChat!
Water spots on finish
Jack Guzman from Maine
I have a table that has water spots.They're white rings. I wiped with alcohol and the spots disappeared but they came back after the alcohol dried. The finish doesn't get sticky with alcohol or with lacquer thinner.It is glossy and has tiny cracks in the finish from age. The client wants me to remove the finish and use something that won't be affected by a glass being set on it. This a coffee table that gets alot of use by house guests. I'm not sure how to proceed and I don't want to start stripping until I get more information.Help?---Jack
Re: Water spots on finish
Stephen Shepherd
Stephen Shepherd
Here is an interesting traditional method of removing white rings from a finish:
Take the meat of a fresh almond or walnut and rub it on the area with cigar ash.
Stephen
Removing Water Spots
Steve Elliott
You have two possible paths here: fixing the white rings in the original finish, and stripping the table and applying a new, more durable finish as the customer requested.
Stephen's suggestion of using a nut meat and cigar ash is a good one. The combination of a very fine abrasive (the ash) and an oil that will seep into the finish will usually greatly reduce or eliminate a white water spot. I've seen recipes for "finish revivers" that use linseed oil and cigarette ash, and I've personally had very good results using a commercial product called "Jasco Furniture White Ring Remover." This is a small cloth that contains the oil and abrasive, and with a lot of rubbing it has taken white rings and scratches off my 95-year-old piano. After use the area repaired will be somewhat shinier than the surrounding areas so you'll need to do some additional rubbing of the surrounding surface to even it out. It will also feel oily for a while but this goes away as the oil oxidizes. The Jasco cloths are available at big box hardware stores.
Personally, I'd prefer to repair an original finish rather than strip and refinish. The customer might also be satisfied with the original finish if he/she knew how to remove water spots easily.
Re: Removing Water Spots
ThomD
There are probably a lot of different rings. There is food on the surface - clean. There is entrapped water - in some cases alcohol will remove this. There are damaged resin finishes, melted in if you like - level and coat. There are all kinds of finishes. A basic cheat repair is to french polish it, and wax a little to even the effect. You can also sorta French Polish with CA glue.
Heres what I do
roninkokomo
Put mayonnaise on the spots. Leave over night. Wipe off
Stephen Shepherd
Will Miracle Whip work? ;}
Stephen Shepherd
Re: Will Miracle Whip work? ;}
Bob Hackett
How about if you spread Miracle Whip over the ring,smoke a cigar and then lick the Miracle Whip off?Will that do it?
After all the word Miracle is right there on the label. :D
