#5 Part Question
Thomas Norton
I posted on"Looking for Something" that I need the lver to adjust the blade . Is this lever attache to the frog? or is it a seperate piece?
Thanks
The one that came with mine is in need of replacement.
#5 Part Question
Thomas Norton
Thanks
Which lever? *LINK*
Do you mean the up and down adjustment (commonly called the yoke) or the side to side adjustment (commonly called the lateral adjustment lever)?
Either way, you've got some choices. Stanley sells parts, including both of these (link below). I can probably dig out a yoke that will probably work from my scrap drawer; e-mail me if this is what you need, with your mailing address.
There are tool sellers, too (Walt Quadrato at Brass City Records and Tools, Clarence Blanchard at the Fine Tool Journal, and Pete Niederberger [a bit more expensive] are good from my experience), but they may want to sell you the whole frog, which then requires you to know which frog you need, which then gets into type studies...
http://www.stanleytoolparts.com/
Re: #5 Part Question
David Miller from Iowa
It is riveted on - it can be replaced by drilling or filing the rivet off and putting another rivet in. Have to be careful because the back of the frog is brittle and can break easily when you whack a rivet (DAMHIKT)
But - you will have to find another frog to take the lever off of, so just spend a little extra time and find the right frog/lever cap and just swap the entire frog out - much easier and you still have the authentic factory look. I'm assuming it is a Stanley #5, which is very common - the frog from the #4 or #5 will fit and it shouldn't be too hard to find one. There are a few different kinds of frogs - just make sure you get the right one
THE ATTACHED PHOTO IS FROM PATRICK LEACH'S BLOOD & GORE - just want to make sure to give him the plug. Shows the 4 different kinds of stanley frog seats. It is probably one of the 2 one the right.
Ditto . . .
steve mackay
I've replaced both before. When I started sliding down the slope I took out the yoke to clean everything. Mistake. Made a mess. DID replace the lateral lever and used a nail as a rivet with Dad's guidance. Won't do that again either. The "satisfaction" wasn't wirth it. Now I try to score a hunk of rust on Da' Bay that has a that part I need in good shape. ie : pay ten bucks for a plane with a cracked sole or hanger hole, use the frog and chuck the rest.
