Re: Chipping on leading edge of lever cap
David Weaver
I have the same thought as the other guys. Unless there is a gap between the iron and the chipbreaker, it's really not going to interfere with anything unless you're one of the few people who actually sets the chipbreaker right on the edge of the iron to increase the effective angle of the cut and actually break chips (like within a few thousandths of the edge).
I don't know of many people who do that. Warren probably knows what effect they'd have in that instance.
Putting a tiny back bevel on an iron has the same effect (to me) in feel and effect cutting anything where you'd need to do that, anyway.
So, I'd ignore it if it doesn't bite you.
My favorite utility smoother is a mujinfang ebony continental style smoother. The leading edge of the chipbreaker is pretty dinged up - I guess they figure you'll file it and clean it up if you want to use it close in. I have not found the need, the front edge of the thing is still dinged up, and it's still a wonderful plane to use.
