New WoodChat!
200+ woodworking book reviews
Removing a stuck tote
I'm cleaning up a No. 5 Bailey that I bought this last Fall (Type 13 sweetheart, gloat, gloat; it will replace a later No. 5 that's been a mainstay for years). Everything's come apart quite nicely until, now, the last step. The nut on top of the tote came off just fine, but the tote won't slide off the rod. I take it that accumulated rust has bonded with the wood. The stuck part appears to be at the top. It's decent rosewood; it's split, but the split's clean enough to glue up. So I hate to have to destroy the tote to save it.
I'm considering wrapping it in plastic, finding space in the freezer, and sneaking it in while my sweetie's not looking, to freeze overnight, and see if that will break the rod loose from the wood.
Any magic tricks?
Re: Removing a stuck tote
Dale Stansbery
First let me say that I have not tried this. But a long time ago somewhere I read that heating a stuck rusty wood screw with a soldering Iron would serve to loosen it from it's moorings. I don't know if you could make enough contact with the end of the screw in the tote to heat it enough, but may be worth a try.
Oh, yeah!  Good idea!
It's in the freezer now, trying cryogenic treatment. If that fails, I'll try going in the other direction. The soldering iron sounds like a good heat source - very targeted, so it wouldn't mess with the wood.
bugbear
It might be worth trying a variation on a technique used to remove wedges from wooden moulding planes.
In this, the wedge is gripped in a vise (giving a large surface area contact), and the plane driven off the wedge by mallet, posssibly via softening blocks, or a softwood "driver".
If you can get a good(enough) grip on your tote, gentle tapping on the body might give results.
BugBear
It came loose
The freezing seems to have broken the metal/wood bond, and determined tugging got it loose. I'll need to ream the hole out with a drill bit before reassembling.
