Derusting auger bits
I've got a bunch of auger bits I'd like to clean up. So far, a vinegar soak (my latest and generally successful rust-removal experiment) has gotten the majority of the rust off of some bits, but getting to shiny pretty hasn't gone so well. Steel wool falls apart fairly quickly, as does the 3M steel wool substitute; sandpaper can't get down into the grooves. I tried belt sander belts torn into strips, but the finest I could get locally, 120 grit, is too coarse (wiped out part of the maker mark on one bit).
I've considered abrasive cords/tapes - although they're kinda pricey - if I can find them locally.
People say mean things about wire wheels on a bench grinder, but I'm considering this next.
Thoughts?
