Hand Tools *LINK*
Stephen Shepherd
http://www.lowtechmagazine.com/2010/12/hand-powered-drilling-tools-and-machines.html
Hand Tools *LINK*
Stephen Shepherd
Decent summary
Decent summary of the history, at least from my not very knowledgeable perspective. The author doesn't get out much, though, and doesn't seem actually to have used a brace much. Some of the lines I liked:
"Hand braces have remained in use ever since [their development], although they can be difficult to find today." Well, yeah, if you don't go to garage or estate sales; but maybe the author meant wooden plated braces. Or maybe the boot and tag sales in Europe (this is a European online publication) don't yield much in the way of braces.
"Although there were a few important competitors, notably Goodell Pratt and North Brothers, Millers Falls dominated the market in the US..." Stanley? Did I hear the name Stanley? At least around here, the majority of the braces I've found have been Stanley products. Nice to have my personal favorite, North Bros., get respect, though.
The author suggests the use of gasoline to clean a dirty brace. It's been my impression that, although the lead's gone, modern gasoline still has a good many additives that discourage its use as a cleaning product. Maybe European gasoline (again, this is a European online publication), or the meaning of the word there, differs.
But, again, a decent summary; and it's nice to see voices other than ours proclaiming the doctrine.
Re: Decent summary
bugbear
The only obvious omission is the blacksmith's brace (beam drill?), where the downwards pressure is provided by a heavy beam, sometimes with weights on the end.
And the author appears to confuse gear ratio (high revs) with power when describing breast drills.
It's sad that all those carefully linked references (kudos!) will go out of date so fast.
BugBear
Beam Drill *LINK*
Stephen Shepherd
Bugbear,
Here is a beam drill I made and use regularly.
Stephen
Beam Drill
Re: Beam Drill *LINK*
Marv
Stephen,
What you have there looks more like a drill or auger press. What are the advantages over a regular brace?
This is what I think of when I think of a beam drill....
http://cgi.ebay.com/Beam-Boring-Machine-Drill-Timber-Frame-Barn-Cabin-1872-/290512462227?pt=LH_DefaultDomain_0&hash=item43a3e46193
Re: Beam Drill
Stephen Shepherd
Marv,
Salaman calls the type I pictured as a beam drill, the one you pictured is called a Wood Boring Machine, I have heard them called timber auger machines.
The advantage to the one I built is that weight can be added to the lever if necessary to provide a constant downward pressure. It can also be operated by holding your free hand on the beam and applying pressure. Its main advantage is that it bores a perfectly straight hole.
Stephen
Re: Beam Drill
bugbear
The blacksmith's ones are mainly about applying pressure - the beams tend to be long, and have "substantial" weights on the end. Vertical is no big deal in this context, since the holes wouldn't be deep.
I've never seen or heard of the small version you've built for your bench, but it's an interesting idea.
BugBear
Re: Beam Drill
Stephen Shepherd
The post is actually intended to be fastened to a wall, which I will do in my new shop, when I get the time. I will also put an adjustable table in the slot on the post. I used holdfasts to clamp it to the bench to use in the interim.
When properly set up, it drills holes like a [and excuse the word] modern drill press.
Stephen
