Adjusting small molding (long & lots-o-pics)
Disclaimers: unlike some of our more organized members, I always forget in-process pictures, so there are some re-enactments in the photos below. And experienced members here will roll their eyes and say, "Well, of course," to what I show here; but I hope some folks newer to the craft will find some helpful information. The presentation is also out of chronological order.
We recently replaced a broken glass panel in an interior door. The original glass was single-strength (3/32") untempered (the door dates from the 1950s or older, back when you didn't think about tempered glass in doors), held in place with 5/16" by 1/4" molding, nailed in. Here's the door:
And you can see, here, the molding in a little more detail:
I wanted to put in tempered glass. Alas, the thinnest available tempered glass was 1/8", which meant either having the molding sticking out past the door a bit (aesthetically bad) or trimming 1/32" off the molding. Sometimes, the smallest adjustments in a piece of stock are the hardest: taking 1" off a 6" wide board is duck soup. What I needed was a variation on a sticking board, an old technique for holding little bits of molding or stock for planing.
Because the molding was half-round with a small reveal on the side that would be down when planing, like this:
I needed something that would hold it from flopping over. Thus, a groove was required. I choose a piece of scrap from one of our current house-remodel projects, a piece of finger-jointed pre-primed cedar. I would come to regret this later, but at the time, it had two virtues: a) the factory edge was straight and smooth, good for the plow plane's fence, and b) it was scrap and not useful for other things.
A little experimentation with my plow plane revealed that the accumulated paint on the molding made it a hair larger than the nominal 1/4", so I needed a 5/16" groove. Plowing is always fun and quick, so I didn't begrudge the extra time spent in making two grooves (posed picture coming), 9/32" deep.
I cut and epoxied a piece of scrap into one end of the larger groove, to make a stop for the molding:
I now digress to something that occurred a while after I did the actual work. When I decided to put this post up, I got to thinking about how I'd have solved the problem of the groove before I owned a plow plane. I now know that the right long-term answer to this problem would have been saving and/or whining until I got the money together to own one; they're marvelously useful tools. But, in the short run, how to do it? I decided a chisel held in a block would be one solution, so I reached for yet another piece of scrap and laid out my cuts:
Working right to left, the first mark is a 45 degree line made with the miter function of my combination square. The second one is the thickness of the selected chisel, and the third is finely judged to allow for a wedge (it looked right, so I drew it). I cut down on the rightmost and leftmost lines 1/4", chiseled out the waste, kinda smoothed out the floor of the resulting dado; made a wedge from (wait for it) some scrap, and assembled my custom plow plane:
I laid out a groove in my board, running the marking gauge over the stock repeatedly to get good deep grooves, and struck lines across each end of my planned groove:
I used a Sharpie to mark a line across the back of the chisel 9/32" from its tip, to serve as a depth gauge...
and roughly chopped down over the length of the groove:
My next step was to knock out the chips (not pictured) and begin planing the bottom "smooth" with my custom plane. Here's where the regrets began to show up. Finger-jointed trim has grain reversals and odd behavior all over the place. Between this and my failure to sharpen the chisel I'd chosen for this experiment, making the groove took me nearly an hour start to finish. With a nice piece of pine and a sharp chisel, it would have been far less. Still, eventually, I had a groove made without having a plow plane:
Other solutions would be using a small router plane; miraculously finding masonite or thin plywood the right thickness and tacking it on each side of a layout, thus making a built-up groove; or whacking the whole thing out with a handheld chisel, and building up the inevitable (at least they would be if I were doing the work) overshot depths with fixall.
At any rate, back to the actual work, now that the preparation of the sticking board is done. This part's just so simple...
I set the molding in the groove (this part's a re-enactment, using some scrap, and, yes, I do have actual boards; it's not all scrap):
You can see a narrow red line above the planing board. That's the "molding," colored with a red magic marker for visibility.
Then I just planed the molding...
until the plane stopped cutting or, in the case of the original planing work, in the center groove, until the plane started removing the primer on the sticking board:
So, when might you use this in your shop if you're too sensible to live in an old house like ours? Well, if you're using stock molding on a piece but need to adjust it slightly to fit the design; or if you're one of those brave souls who planes molding on the edge of a board then rips it off (the books always make that sound so simple); or if you shaped a small piece of stock for a project and discovered, as you attempted to install it, that you'd goofed slightly on your dimensions.
A couple of other notes:
1. For some molding patterns, getting the side you need to plane upright while supporting the molding might require a two-level groove or some sort of filler in one side of the groove.
2. While this was coincidental due to the size of the molding, I found the board a real help in setting the brads into the molding before installing it. It's always difficult and a little terrifying trying to start a brad in molding that's held up against a piece of glass, even tempered glass. I was able to set the brads just sticking out the bottom of the molding and do the last hammering with far more security by setting the molding down in the groove to hold it still. For some tricky jobs, a variant on this idea might be helpful.
