Saw handle wood ID?
Bob Entwisle in NJ
Please help a wood identification moron, uh, I mean a "wood identification challenged person", identify the species of this saw handle.
Thanks
Bob in NJ
Saw handle wood ID?
Bob Entwisle in NJ
Thanks
Bob in NJ
Re: Saw handle wood ID?
Bruce, a MN Galoot
Not positive, but it looks like apple to me.
Second that.
Bob Hackett
Looks like apple to me too.Just don`t ask what kind of apple.
Stephen Shepherd
Bob,
From your description last night on the Hand Tool Chat, I suspected it was apple, and now from the picture, I am sure.
Stephen
Very nice wood/saw handle porn there
Dale Lenz
Assuming the wood was not filled with a filler, is the wood tight grain, like cherry or open grain like oak?
Marv
Bob,
Your handle appears to be off a Disston No.4..... 8 or 10" backsaw that used only two saw screws. Probably was made prior to 1928 when Disston was using Applewood on their backsaws. After 1928, they switched to using Beech, but yours definitely is Applewood that has been nicely stripped down to bare wood.
Marv
Re: Saw handle, here is the rest of it
Bob Entwisle in NJ
Thank you everyone for answering
and confirming the Apple suspicions.
The wood is very tight grained. I sanded the old finish off, and the picture was taken just after one coat of a BLO/Turps/Varnish mixture.
The blade is 12" long, 14 TPI, No etch on the blade. The back is Steel with no markings on it that I can find. The medallion is a "WARRANTED SUPERIOR" with an eagle, no stars, 13/16" Dia. The blade was a little less than straight and was filed crosscut when I got it. I finally got over my reluctance, and beat on it with various hammers and such and was able to straighten out the blade. Since this was/is my "learn to sharpen" saw, I refiled it to a rip profile. I attached the handle tonight with the one sawnut/screw that I have and gave it a try though some soft maple that was lying around and it seems to cut very well, which for my first effort at sharpening a saw, is very pleasing to me.
I do need to dig through my hardware collections and see about finding a sawnut/screw for the second screw. Or worse, or off to a garage sale to find a 'parts saw', thought that will likely lead me down a path to refurbishing another saw, and that could lead to JD Green painted handles and who know what else!
I probably have a sawnut if you can't find one. E-mail me with the thickness of the handle and the diameter of the hole, and I'll dig through MY hardware collection.
Marv
Will be looking forward to a nice deep luster John Green finish. But not on Applewood, please!
just as a reminder, so no one will forget what John Deere green looks like, here it is again....
Oophh, Akkkk, Errrkkk...
Scott Burr in Ben Lomond CA
Where's the head, I'm gonna Puk...
Happy Holidaze Marv!
I hesitate to say it but...
Bob Hackett
Don`t you think the wheat carving would be shown to better effect if you had carved it AFTER painting?
For a more historically correct application I would further suggest the possible carving after application of green and then carefully painting the carved areas with the appropriate shade of yellow.Perhaps a magnifying visor and arm rests would need to be brought into play.
Must stop now,hands cramping,forces of karma attack.ARGHHHH!!!
Re: I hesitate to say it but...
Marv
Bob,
Oh come on Bob, ya know ya like it!
Thanks for the suggestion. I suppose I can still recarve the wheats, then fill with JD yellow. I had actually thought of doing that but was hoping that the shiney saw screws might take the place of yellow paint. Painting those individual wheats would be quite tedious. I'm sure I'd mess out of the lines and just make a mess of it.
Doing the wheat carving after painting the green is a good idea, but then just leave the wheats dark or natural wood color might look good. Maybe give it a coat of clear lacquer. Whataya think?
Marv
Perfect solution
Bob Hackett
You make your own handles right?
Instead of using wood get a chunk of bright yellow plastic and make one out of that then paint it green using that new Krylon paint made just for plastic and carve thru the paint to expose the yellow plastic.
Hands cramping again,going blind,can`t see screen,ARGGHH!!
PS-you`ll still have to paint the saw nuts and medallion yellow to match the plastic.If you`re really "in the zone" and the saw has a faint etch you may consider painting a tractor where the remnants of the etch used to be and filing the nib to look like a plow in order to keep with the theme.Details make all the difference you know.
Must lay down now till this passes.
Re: Perfect solution
Marv
Good Gawd, Bob, all of that just so I can have yellow wheats? Plastic handle? Now yer making ME gag! I know it's hard to believe, but I do have my limits.
The river is wide, and the slope is slippery
Seems like a short step from Bob's suggestion to farmyard scenes all over the saw...
I will stop thinking about this now.
Tom MacGregor
Don't forget to trace around it with a black magic marker when you hang it on the pegboard.
Or, if you want to go first cabin,
white paint, with "saw" painted in the middle of the space.
As one of my co-workers used to say,
Bob Hackett
"I see said the blind carpenter as he took out his hammer and saw".
