New WoodChat!
Mortise gauge?
Mortise gauge?
Mortise gauge?
I'm looking for a good mortise gauge. Before my shop burned down, I had several styles of typical rosewood gauges, some with brass wear strips, some with thumbscrews, some with screw feeds. I never got a replacement and now I'm sick of not having one.
Someone gave me a cheap Japanese mortise gauge a while back. I'd use it if I could, but I can't seem to tune it up well, and it's really clumsy to try to hold the spacing while adjusting both blades in and out to set the distance. It took me an hour to file the parts cleanly so they mate smoothly and to grind the knives to the same height so they both contact the wood evenly. It's still too much aggravation for me. I'm giving up.
Sooooo.... where can I find a decent mortise gauge for not a lot of money and what kind of gauge would you recommend? Any really functional design is fine -- it doesn't have to be rosewood or fancy. And is there a place where someone could gift-order one for me for a Christmas present?
Thoughts?
Re: Mortise gauge?
Jack Guzman from Maine
Re: Mortise gauge?
Ellis,
If I were looking for a good mortise gauge I'd look for an antique. There are a few nice ones made today but they are pricey.The cheap ones made today aren't too good. Patrick Leach usually has a few nice ones every month in his newsletter and if not he can usually find one for you.---Jack
Re: Mortise gauge?
Search eBay Stanley 77 Rosewood
David Miller from Iowa
Make sure you can see the knives before you buy
Re: Mortise gauge?
Boy, that's for sure
I've picked up a couple of gauges online - unless the pins are easily adjustable, I'm not doing that again. The pins were filed away to the point that they're imaginary.
Re: Mortise gauge?
Re: Mortise gauge? *LINK*
Pam Niedermayer - Austin, TX
I've got one that looks pretty much like the one in this auction. It's very good and weighted nicely; but I use Japanese marking gauges these days, so am in the process of selling most all of these old western tools. If you're interested, I'll photograph mine, let you set the price. I owe you for not getting that plane done yet, still a mess in the shop.
Pam
ebony gauge
Re: Mortise gauge?
Before you purchase another, try this ...
Hi Ellis
I have one of those Japanese gauges, although it is not a cheapie - it was a wonderful gift from Wiley (a gentleman I have not seen here for a long while ...?). There is a technique, indeed that Wiley showed me, that makes setting up this type of gauge very easy. And this includes any mortice gauge for that matter.
Step 1: mark the outer edges of the mortice width. Here I have used my mortice chisel to do so.
Step 2: place the mortice gauge knives at the ends of the indent and gently press these down into the wood.
Step 3: Now slide the head of the gauge against the work piece to set its depth. This completes setting up the mortice gauge.
There is a bit more in this article on my website: A Primer for Mortice-and-Tenon Joints http://www.inthewoodshop.com/Furniture/AHandcutMorticeandTenonPrimer-BlindMortice.html
Re: Mortise gauge?
Of course!
I'm sorry, but that's way too easy. Talk about a head-slapping moment.
Thanks for the nice little tutorial.
Cheers,
Re: Mortise gauge?
Thanks, Pam
I appreciate your offer. At this point, I'm going to hang back and wait for either Christmas or the gauge fairy. I'll let you know how that works out.
Re: Mortise gauge?
Why not make your own
Patrick Gibbons
Re: Mortise gauge?
Take her up on it!
CJ in MPLS
I've got the same one and I love it. It has the added benefit of weighing enough to be used as a shop defense weapon. ;)
Re: Mortise gauge?
Re: Mortise gauge?
R.J.Whelan
Ellis,
I have several of the Glen-Drake Tite Mark gauges and like them as well as any I've ever owned.
RJ
Re: Mortise gauge?
Re: Mortise gauge?
bugbear
How many different widths of mortise chisels do you have (or more importantly, routinely use) ?
BugBear
Re: Mortise gauge?
Ditto. Great Gauges.
Hank Knight
Re: Mortise gauge?
Re: Of course!
Also, you need to hold the gauge with your palm on the bottom, not the top, two fingers in front wrapped up around the body.
Pam
Re: Mortise gauge?
another vote for the Glen-Drake
Scott in Montana
Re: Mortise gauge?
Re: Why not make your own
I don't have metalworking capabilities here or I would. Time is also in short supply. Maybe you have a design in mind...?
Re: Mortise gauge?
TITE-MARK!!!!!!!!!! *LINK*
charlie belden
You want something that you can set up quickly and easily - and have it stay there. A single bevel edge makes registering a chisel accurately almost a no brainer. Single bevel wheel cutter doesn't wander when going with the grain - even with oak. With the pair of mortise wheels it's easy to set them to the width of the chisel you plan on using - then with the micro adjustable fence - put the cutting wheels right where you want them. And you can used an existing set of scribe lines to reset the cutting wheel or wheels.
For the price of one of those pretty rosewood gauges - that you have to fuss with and resharpen regularly . . .
This is definitely one of those Buy Once, Cry Once tools. Buy it and never buy another marking gauge - or cuss and swear when something slips - and you find out later.
2 pages on the Tite Mark
Re: Mortise gauge?
Patrick Gibbons
Make them with fixed pins in the sizes you use and you don't have to worry about metalworking capabilities.
Re: Mortise gauge?
Dean J in MN
I'll second Patrick's suggestion of fixed pins. Easy to make, never go out of adjustment and are consistent from use to use. It is easy to set your pins a bit different each time you set off your mortise chisel -- These fixed pin gauges are always the same so you know just were to saw for the tenon, leave/split/take the line remains constant.
