New WoodChat!
Have a question? Ask Woody!
I guess my wife is right
David Miller from Iowa
So our first grandbaby is coming to stay for a week over the holiday - crawling age. But we have a treacherous stairwell. So my wife tells me to go buy a baby gate at the store. They were all cheap and ugly, so I tell her I'll just make one. And she says there you go again, we just need a baby gate, not a huge cherry wood project that will be mission style to match all the cupboards (which I also made). Just go buy a cheap one, she says, you always make everything into a big deal. I hate it when she knows what i will do before I know myself.
Re: I guess my wife is right
Yeah, but just for the record
Bruce, a MN Galoot
She was right, and you did a great job! It looks like it belongs there. Nice work.
I'd say half-right
that one doesn't look like it took too awfully long a time - and it's way, way better looking than the cheap ones.
Hey....if you are gonna do a job....do it right! BTW....I love those bullet hinges....nice touch.
Tom
Moses Yoder
Re: Question
Moses Yoder
It looks great, I like the hinges. How did you attach the diagonal piece to the stiles?
Re: Question
The hinges are lift-off boat hardware - I can lift the gate right off, although I put some tension in them so the child would have a harder time getting them off.
I just glued and nailed the diagonal brace on - it starts and ends in a mortise in the sides. Just put a spot of glue on the intersection, clamped it and shot it with an air pin nailer
When my SO says that,
Chuck Nickerson
she's implying it won't get done in time. She's almost always correct.
looks great but........
Larry Williams
I'm impressed David but there is one thing. I always do what I can to put diagonal braces in compression rather than tension. In tension you're depending on fasteners and compression uses the strength of the wood with the fasteners or joinery just playing a supporting role.
Re: looks great but........
Pam Niedermayer - Austin, TX
Are you saying you'd have built the diagonal to go from top left to bottom right? And if so, how is it that would be compression, because the bottom right is stationary of sorts?
Thanks,
Pam, who thought she understood compression and tension, but maybe not
Moses Yoder
Moses Yoder
I think he is saying the pressure would go on the top left as you are looking at the gate picture, wich would pull the diagonal down, putting it in tension. If the diagonal ran from top left to bottom right and you put pressure on the top left it would put compression on the diagonal. I guess it is about the same thing as using yellow glue for veneering ;)
That is beautiful work
Jay Samuels
Almost makes up for that picture of the 55.
R Payne
I think if she was really ok with a cheap, ugly, plastic thing she would have bought one herself. Since she asked you to buy it, knowing you'd make it instead, she didn't really want a cheap, ugly, plastic thing. She's just giving you grief.
nice work.
ron
Thanks, Moses, that's what I figured.
You're right Larry
I mocked it up both ways and, of course, you are right that wood is always better under longitudinal compression than tension, but it didn't look as good to me. Doubt that it will matter with this little 4 pound gate, but your point is certainly valid.
Another question
Hi David
That is waaay better than the one I built. I particularly like the posts on the corners - that is a great detail. One question: when the little tyke is not around, and you do not need the gate (it might be a pain to open/shut frequently) ... assuming that the construction stays ... is the gate left open (along the wall?), and if so, how is it held/kept that way?
Re: Another question
The concept for this is to to install and remove as needed but,despite being somewhat massive, it did need a good anchor system. I originally was going to anchor each side pillar into the hardwood floor, but I just couldn't bring myself to screw into the ash flooring which would leave scars when the gate was put away.
Happily, there are some major structural beams behind the drywall in this location, and each side pillar is locked in with just one (quite substantial) screw horizontally through the middle attaching it to the wall. There will be a drywall scar, one on each side, but I'll make a cute little finial plug button to stick in there when the gate is put away.
