New WoodChat!
Raising a burr
Raising a burr
karl jr
Raising a burr
karl jr
Hi all!
I usually hang out over on the round side, and I've got a hand tool question. Is there a quick and dirty way to raise a burr on a card scraper? Or must I go through the entire process of filing and then honing, and then raise a burr?
Re: Raising a burr
Moses Yoder
Re: Raising a burr
Moses Yoder
I usually turn the burr 3 or 4 times between honing. I make about 3 or 4 passes with the scraper flat on a table then hold it upright in my hand and turn the burr at about 10-15 degrees. When it won't cut right anymore it needs to be honed again.
Re: Raising a burr
karl jr
LOL
karl jr
LOL! "Turn the burr," says Moses. The joke's on me!
Seriously, thanks. I know now what I was doing wrong.
KTK
Re: Raising a burr
For some work...
Bob Hackett
I find a scraper easier to use without a burr.Just file,hone and go to work.
When it stops cutting ribbons (and starts raising dust) I pull out my pocket diamond hone and refresh the edge.
Re: Raising a burr
karl jr
Re: For some work...
karl jr
I've obviously got some learnin' to do. You and Moses both have given me something to think about while I'm working. Turning a burr is something that I wasn't really doing. I suppose my honing skills also nee some, er, honing.
At any rate the scraper has been working out all right, once I got it kind of figured out.
I've been using the scrapers on natural edge bowls, btw. They've saved me a lot of sanding, and I get a better surface to boot. Holding on to the sucker while scraping the inside of a bowl has been interesting, let me tell ya.
Thanks
17 bowls out the door, and 18 to go on friday
KTK
Re: Raising a burr
Turning the burr
Bob Hackett
The first thing I had to understand was to use a light touch.I was thinking"I`m bending steel here,better put some grunt behind it".Not so,too much pressure curls the burr to the point where it has to be laid down at a steep angle to cut if it cuts at all.
A little dab of light oil on the burnisher and a light touch will do the trick.
I too use them to smooth the insides of natural edge bowls especially those 2 areas that fuzz up coming into and out of the end grain.They work some slick,don`t they. :)
