New WoodChat!
1/4" SKEW
1/4" SKEW
1/4" SKEW
Nick Tuzzolino
The skew is for turning, obviously, but you hand tool fellows probably have a broader area of metal knowledge than the turners.
So, I want to make a small 1/4" skew. Can I use water hardening drill rod, grind to specs, and just use it. Or is there more involved?
Re: 1/4" SKEW
Re: 1/4" SKEW
Bruce, a MN Galoot
Most of the drill rod I've used comes annealed, so you'd have to harden it, too. But with W-1 that's not hard.
Re: 1/4" SKEW
Re: 1/4" SKEW
Bob Hackett
For rolling small details like beads you may be better off buying a 1/4" rod of HSS and grinding your bevels on the end of that.Much more user friendly and no heat treating needed. :D
Re: 1/4" SKEW
Re: 1/4" SKEW
Nick Tuzzolino
Shows how much I know about metal working. High speed steel is what I had in mind. Duh!. THANKS!! to all. I have a metal/machine shop supply nearby.
Re: 1/4" SKEW
Moses Yoder
Re: 1/4" SKEW
Moses Yoder
If you grind metal that is already hardened you have to keep it cool enough during the grinding that it will not lose it's temper. The best way to do this is by grinding it a little bit then wrapping your palm around the tip until cool, etc. ad infinitum. Supposedly if you dip it in water to cool it can cause very minute fractures in the steel, although I have used this method also.
Re: 1/4" SKEW
David Barnett
Actually, you can grind HSS to red heat...
David Barnett
...without diminishing its toughness or drawing its temper.
