Flat Hand Axe
Doug Reynolds in Seattle
What is a hand axe (hatchet) that is flat on one face called and used for? I'm thinking it is a hewing axe but, may be wrong.
Flat Hand Axe
Re: Flat Hand Axe
Jay Samuels
Doug: I would call it a broad hatchet or a side hatchet. It's good for rough wood removal if it is sharp and your technique is good. Then you can drawknife, spokeshave or plane. And for putting points on stakes if you chop down onto a stump or piece of firewood (recently did 36 of those). Keep your free hand above the cutting edge. Jay
Concur
Probably lots of regional names. I've seen them just called "single-bevel hatchet."
It's definitely the woodworking hatchet. Double-bevel hatchets are for light limbing of trees, splitting kindling, things like that.
Re: Flat Hand Axe
Warren in Lancaster, PA
A hatchet is also useful for preparing stock for turning, whether riven stuff or sawn, making it roughly round. I often see a stump and a hatchet in an old drawing of a turner shop; I don't think I have ever seen a shaving horse in an old drawing of a turner or a joiner's shop.
Broad hatchet
Adam Cherubini
I have a couple of these and find them very useful. As Jay said, they are used for rough stock removal, but it may be helpful to define that term more narrowly. A normal hatchet is good for rough stock removal. The broad hatchet has the unique ability to remove wood in the direction of the swing. This allows you to pare off thin shavings of wood as in the ancient rhyme:
The broad axe said without a miss,
he said the plane my brother is
We two shall clense and make full plain
In our shops, the broad axes can be used with short, slow, deliberate strokes to remove stock not unlike one would with a draw knife. The advantage of the hatchet being that no shave horse is required and the work can be done faster. If you had a board tthat needed 1/2" removed, especially form one spot, you could do that quicker with a hatchet than a scrub plane and be let with as good or better a surface.
While you can hew cross grain with a hatchet, I've not found that as useful for common furniture projects (or with sawn boards)(tho I've done it a fair bit) More common is working with the grain.
My rule for using this tool is that the bit (edge) must never raise above the hand holding the stock (imagine chopping down against a bench or stump.
Familairity will open yoru woodworking to the wealth of free wood that you can find in the forest, on your property, out by the curb etc etc.
The broad axes is not a crude tool, but one capable of quite fine work. Mine is as sharp as a kitchen knife. Note that old broad hatchets "flat sides" aren't flat at all. They are crowned slightly (higher in the middle) and their blade should be accordingly curved. In use, they produce nice scallops like a fore plane's shavings.
