New WoodChat!
Bees wax question
Bees wax question
Bees wax question
Joe in a Cleveland suburb
I remember watching a Roy Underhill episode on line some time ago where he made a, I think it was called, dovetailed grease pot. In it he put some kind of mutton fat/grease or wax or something. When I re-watch the episode, he says it so fast that I am not sure what he is saying.
But I saw something about it recently and wondered about a hard chunk of bees wax I have. Using this wax, I sometimes scribble some wax lines on the bottom of a plane, or on a hand saw, screws, and/or similar uses.
I kinda remember reading here a while ago about melting wax and mixing in some kind of solvent to make a softer wax that would stay soft. Something like Crisco that you could put on your plane sole, screws, and so on.
Am I way off base in remembering this? Can you tell me the process of doing this?
Thanks!
Re: Bees wax question
Turpentine?
Was it possibly turpentine? I know that mixing turpentine with beeswax will make a soft wax finish.
Tom
Ask Stephen Shepherd.
Dan Donaldson
Frank D. in Montreal
Hi Joe,
I can't comment on what was already said on the subject, but I make my own paste wax, and any mineral-based solvent will do the trick. I prefer low-odour mineral spirit like Varsol or even better, Izosol. They smell less than paint thinner and are less toxic than paint thinner or turpentine. For some added glide and for a mixture that will stay on longer, add a bit of carnauba wax to the mix. You can get the consistency you like by simply adding more solvent to the wax flakes or pellets. I don't even heat the mixture: just add enough solvent to cover the wax, then stir three or four times during the first 24 hours. After that, add more solvent if you want a thinner consistency. The wax should fully dissolve at room temp within 3 days. I much prefer wax over tallow any time.
Stephen Shepherd
Stephen Shepherd
I mix up half lard and half beeswax, warm the mixture taking care not to burn it; makes nice stuff for your grease box.
Stephen
Re: Bees wax question - tallow ??
John Aniano in Central NJ
Joe,
Perhaps you were remembering an article in a recent issue of Popular Woodworking, detailing the use of mutton fat or tallow on the bottom of plane soles? From the PW site : "Roy Underhill shares Tallow Tales & Black Planes of Britain in Arts & Mysteries" in the August 2010 issue.
Is that it?
John
Jerry Nicholson
I have had better luck dissolving beeswax with mineral spirits than with turpentine. Smells better too!
Jerry
