New WoodChat!
uses of old cotton housecoat material
I have an old housecoat - the label's too faded to read, but it feels like 100% cotton - that has outlived its original purpose (neck area's worn out from the nail I've been hanging it on) but is still solid over most of its area.
I'm thinking this might be good material for a tool roll - it's not as hard a finish as canvas, but is still a thick and heavy weave. Am I right about it being OK? Are there other uses I should consider for it?
Bill, bottom feeding off fabric now
Re: uses of old cotton housecoat material
Bob Hackett
I think it would be ideal for a tool roll and based on the many old ones that I`ve seen hundreds of others agree with you too.Heavy cotton or canvas sail cloth are the preferred material for tool rolls up here.
One of the beauties of things like cotton and canvas rolls is that you can soak them in oil to both keep the tools from rusting and also make them water repellent.
A tool roll, or...
James Watriss
I'm a little weird. You guys know this.
I've started keeping fabrics around the shop for bizarre repairs or improvised fixes for things, using a composite with fabric and glue or epoxy.
Years ago, I made a longer handle for my Veritas journeyman's mallet... only to find that the screw that goes into the end would split the wood after a few weeks of thumping. (No wonder the stock handle is so short.) I fixed this by wrapping a 3/4" wide strip of rag, soaked in yellow glue, around the handle, to hold the split together. Problem solved, it's still thumping merrily 4 years later.
I made a vacuum hose adapter (different diameters) with a scrap of old coverall and some epoxy.
There are other less worthy things I've done, but the short of it is that I don't throw fabric away anymore... it's too useful.
So Jimmy me boy,
Bob Hackett
Sure and you have some fine stories about leather now don`t ya? :D
Re: A tool roll, or...
Bruce, a MN Galoot
and you should see what the knife-making guys do with a little denim and epoxy - VOILA! - denim micarta. The stuff looks great.
