An afternoon with new shop friends
It's been 6 weeks since I spent any time building something in my shop (a gennou handle does not count). This afternoon I spent some time with a few new tools, which I thought I would share with all of you. Be warned, this post is picture heavy!
Some time back I had come across an interesting board at the local Borg. It was on the rack with pine, but it was unlike anything I had seen. I grabbed it as it looked like it would make an interesting box. Here it is cleaned up ...
So I prepared a piece of Karri (very, very hard wood ... similar to Jarrah in looks. This began life as ex-roofing timber).
Another use for a Veritas skew block plane - working across the grain ...
One of the new friends was this 3 1/2" adjustable square gift from Stu, a mate in Japan.
Stu had sent me three Koyamaichi dovetail chisels that Mr Koyama had ground to my specification - minimum shoulders - and I was looking forward to trying them out with the new gennou I had handled (posted recently).
I also got a chance to use the new LV mini edge plane. I thought that this would be useful when building small boxes with thin sides ..
Look at these shavings!
Back to the box. I had not cut a dovetail in about 8 weeks. I was determined that this would go saw-to-saw. No excuses ..
Still getting to know this saw, but it is real sweet ..
Now the other new tool was the production version of the Knew Concepts fretsaw I had some input into. This is 5" in depth, with a Titanium frame, and the blade angle can be set at 45 degrees either side as well as 90 degrees.
Lee has been supplying it with an Eclipse 18 tpi blade, one that I recommended. The combination is outstanding.
The chisels worked well ..
Look at the tight fit at the shoulder ..
Marking the cheesy pine was "interesting".
It cut easily but I was concerned how fragile it would be ..
Finished ..
Now would it go together?
Dovetails ..
The base is yet to be done. There is some pine left for that (after the lid is cut open).
Thanks for sharing this with me.
