Making a scraper
Jerry Gibbs
Is it practical to make scraper out of a carpenter's saw? I need one with about a 2" radius. I don't have any special metal tools other than a hacksaw and a grinder. Thanks
Making a scraper
Jerry Gibbs
yes
David Miller from Iowa
But check the temper first by trying to burnish a hook on the top of the blade - they were tempered from the bottom up and sometimes the top will roll into a hook and other times it is too hard. A real old Disston may be good for this the top, but a lot of the "middle aged" ones were tempered up too high (i.e. quality too good). This is a case where a cheap 1960s saw might actually be better. I'd get a bunch of $1 saws at a garage sale and try to burnish the tops - some will be way better than others.
I use an angle grinder to cut these, but this leaves a 1/4" zone of ruined metal that you have to take off by grinding slowly so it doesn't get too hot. I just cut it with the angle grinder, and then grind the edges in a 1" belt sander, taking care to cool the metal in water after each pass.
Re: Making a scraper
ThomD
First off it's a lot easier to make a scraper than a saw, and a lot easier to get steel for a scraper, than a saw, if the saw is at all worthy. But if it is truly a throw away saw... It's hard to hack saw thin steel. And some saw steel could be too hard. To improve your chances try backing it with something like a piece of wood, so the teeth have more bearing. Choose wood the hacksaw easily cuts.
You can score it with a grinder and snap it, or grind full through it. Keep in mind that if you enter the metal working arena, which I guess we all do to some extent, it means you will need a cornial x-ray before you can have an MRI, and corneas are not something you want to x-ray.
Bruce, a MN Galoot
a Dremel with a cut-off wheel will work to score the metal. Then clamp it to a bench with the score line right at the edge of the bench and bend. It'll break.
Old saws make good scrapers, I've made many. Just don't sacrifice a good saw for it.
Oh yeah, you'll need a file and eye protection, too.
Stephen Shepherd
You should get a pair of tinsnips for the job. Much quieter and much faster. I have only found one saw blade I couldn't cut with my tinsnips.
Stephen
practical?
Jerry Gibbs
Checked with Lee Valley and WoodCraft. Can get a set of 4 concave/convex scrapers for less than $20. I do have several old handsaws and I like recycling, so I will try it.
Jack Guzman from Maine
Jerry,
I use sawblade stock for scratch stock. I break it into a rough size in a vise and file/grind to shape. Everyone sells scrapers.They're cheap,so I just buy mine.---Jack
Blueing the steel
Bob Hackett
If you have a good sharp cold chisel(look in the drawer,we all have one we just need to sharpen them) you can cut metal without fouling up the temper.
Find something like a piece of pipe or other steel object whose radius meets what you need.Clamp the saw in your vice with the object and the steel both between the jaws and sticking up where you can get the chisel on it.
Sheer thru the metal using your round object as a backer,chisel edge roughly 45 degrees to the metal.
What you are basically doing is the same as using a pair or snips.The chisel is one side of the snips and the backer the other.
Much quicker and easier than having to grind the blue away.
Dominic in Buck's County PA
You wrote:
"I use sawblade stock for scratch stock. I break it into a rough size in a vise and file/grind to shape. Everyone sells scrapers.They're cheap,so I just buy mine. "
Yeah, EVERYONE sells them! And if you look in the Classifieds, you might see someone selling them!
See ya around,
Dominic
I use old pullsaw blades
steven antonucci
Once enough teeth have broken off or they get kinked, I use the steel in those disposable blades to make scrapers. They work very well at cleaning up the bowls of the spoons I carve.
S
