We value your privacy.
I managed to scare up a MF Acme Landon miter saw at a garage sale last summer. The blade is in good condition, as is the whole miter gauge, but the cutting edge is so dished that it can't cut all the way through anything, even at the lowest setting. It needs to be jointed and filed.
Does anyone know the rake and fleam angles for this saw? The teeth are so rounded over it's difficult to tell.
Does it have 10PPI? (points per inch) The bigger saws are usually 10PPI
I would go with no less than 15 degree rake and 25 degree fleam. Joint the sides of the teeth lightly after setting. And if it's a bit grabby at first, slide a slip stone lightly down the points of the teeth.
When you first start heavily jointing, joint both ends first and file those teeth first, then joint again at each end and file all the teeth that have flats. Keep doing that until you get a a flat on the middle teeth where the worst of the dip is. In other words, don't remove all the teeth at first or you won't know where the gullets should be. When you heavily joint, always leave some of the gullet.
In addition to the information, you answered the question I hadn't properly asked. I had no idea how I was going to maintain the proper teeth spacing while trying to straighten the crooked line.
