New WoodChat!
Cheese Saw
Cheese Saw
Stephen Shepherd
Cheese Saw
Stephen Shepherd
I couldn't find a decent cheese cutting tool in the stores, so I had a blacksmith friend of mine make me this frame, copied from an artifact. The handle and the wire were missing on the original. Curly maple handle finished with hemp seed oil and a piano wire blade with zero teeth per inch, or is that gullets per inch, none of those either. The cheese is hard Parmesan.
Stephen
Re: Cheese Saw
Nice
You even managed a nib, kind of.
If we were still eating cheese, I'd be adding this to my list of things I'd like to do.
Re: Cheese Saw
Re: Cheese Saw
Greg B�tit, Crown Point, NY
The engineer in me sees that saw not being able to cut the last 1/4" or so down through the cheese. Must make for unsightly cut ends. :) Now you see why I tend to leave the engineer behind when I go into my shop.
Nice rig Stephen. I need to make one for my 18th century reenacting kit.
greg
Re: Cheese Saw
Re: Cheese Saw
Marv
Greg,
I was thinking the same thing.
The handle should be higher and the piano wire should be attached at the very bottom of the two vertical struts. The frame could be a simple U shape with the handle attached with enough clearance on the underside for fingers and so the fingers don't touch whatever the cheese is being cut on.
Or, the cheese cutter in the picture could be used to slice the cheese off the top or side while holding the block of cheese in one hand and slicing with the other. When the block gets to where it can't be sliced, ya just shove the remainder in your mouth and eat it. :D
Marv
Re: Cheese Saw
Very nice, I want one!
John in NM
Re: Cheese Saw
Re: Cheese Saw
Charles Jackson III
nice looking saw.
Re: Cheese Saw
Re: Cheese Saw
darin
It works fine just turn 90 degrees. When I was young I remember a similar device made up by bending wire to approximate the shape of Steven,s wonderful recreation.
