New WoodChat!
Several Windsor Chair Questions
Mike in Suffolk Va
I am building a couple of new style chairs for me. I currently have a child�s sack back rocker legged up. Do I need to level the chair prior to fitting the rockers? Do I need to use the same proportions for leveling the seat to the floor? (Front � to � inch higher than the back of the seat) How do you cut and fit your legs to the rocker? (Rug cutter rockers) How do you position the chair on the rockers? Is there anything else that I should be aware of?
I am copying a 9 spindle balloon back chair for one of the local cities. I am also copying a seven spindle balloon back as well. The bow on the 9 spindle has a �D� shape cross section. Do I shave it square, knock off the two corners, and round over from that point? The face of the bow has a bead on the inside and outside edges. What would you recommend to apply the beads? Should I apply the beads before or after bending? The 9 spindle does not have as much �re-curve� as the 7 spindle. Using the measurements of the original chair bow, my sight lines ran parallel to the center line of the seat with a 14 degree back lean. Is there anything that I need to be aware of while fitting the bow to the seat? The 7 spindle has what appears to be a re-curve at the bottom of the bow next to the seat. I have not worked up my angles or sight lines for the bow on this chair.
I have ran into an additional problem. On the ballon back how do you get the bow to go into or form the pinched waist? I tried a back up piece that I tried to drive in with wedges but that did not work. Any sugestions. Anything to be on the lookout for here? Thanks in advance for any and all help that you provide.
Mike in Suffolk VA
Re: Several Windsor Chair Questions
Jim Crammond in Monroe, Mi.
Mike,
I have made a couple of rockers so I am by no means an expert. I leveled the legs before installing the rockers, if I remember correctly, the seat had more lean to it than in a normal chair, 2" front to back instead of 1". I made the rockers with a 42" radius (these were full size chairs) To attach the rockers, I cut out the leg to accept the rocker and then glued and pinned the joint. I do remember that it was difficult finding any information about how to go about this.
For the bow, to make a D shape do as you suggested, make a square or rectangle and then round off the back corners. I have made the bead using a scratch stock both before and after bending. I think it is easier before bending because you don't have to follow a curve.
Jim
