What chip breaker are you using? (long)
Scott Burr in Ben Lomond CA
The original or an after market one? Here's a little something that might be of help from Chris's blog:
"Woodworking Magazine" - 1 new article
When Your Plane Iron Won't Retract All the Way
Reason No. 50 that I dislike chipbreakers: They can prevent your iron from retracting all the way into the mouth of the tool.
Sometimes I think chipbreakers are a cruel joke on the woodworking community. Before chipbreakers (and the invention of pants) everyone was dandy. Nobody had a problem with setting their breaker (or with pantslessness).
But then somebody had to go and invent the breaker/cap iron/second iron/ whatever it is you want to call it. And now we are stuck with it in our Bailey-style bench planes.
It promotes clogging. It adds complexity to the tool. It can interfere with the way the plane's adjuster works. And the problems it causes can be difficult for beginners to diagnose.
Here's one I ran into this weekend. I had almost forgotten about this problem, but it happens a lot and flummoxes even veteran woodworkers who haven't encountered it.
Let's say you tighten up the mouth of your plane and then you can't get the tool's cutter to retract all the way. The adjusting wheel just bottoms out against the frog and won't budge. It seems like you are stuck and that it's time to send the tool back to the maker.
Nope. The fix is easy.
The problem is the chipbreaker is too long. You see, the chipbreaker engages the plane's iron assembly. If the breaker is too long it will prevent the iron from retracting, especially when the mouth is set tight. (There is some geometry involved here because the frog moves forward on an inclined plane.)
So if you grind back the chipbreaker's leading edge, you will fix the problem instantly. Do this on the grinder, just like you would grind the cutter. Most breakers will intersect the iron at 25�, so that's a good angle to begin with. With new-, very old- and infill-style chipbreakers (a flat piece of iron), this is just like grinding an iron. With the springy breakers on Stanley planes, you might need to re-bend the sucker a bit before you screw it to the cutter.
All this sounds difficult, but it's easy work. The steel in chipbreakers is soft, so it takes a minute at most. And you usually have quite a bit of leeway � you can grind away about 1/8" of the breaker without changing the way it mates with the iron. Note that some modern chipbreakers have a small land (flat area) on the underside. Don't grind all that away � that's where it mates with the cutter.
I usually grind away about 1/16" � that has fixed every problem so far.
Do this before you start messing with the dog that engages the chipbreaker or (egads) bending the yoke of the tool (which is many times made using cast metal and will many times break).
� Christopher Schwarz
That said, if I was in Denver I take to the Woodcraft and hook-up with Rob before any modifications were made to the plane.
