New WoodChat!
Kenyon saw handle scanned on graph paper...
John Aniano in Central NJ
Hello All,
For those truly interested in "over-engineering" a Kenyon copy, here is the handle scanned on top of graph paper. The dark regions to the right of any edges are shadows inherent to the mechanism of the scanner. Sorry. This image coupled with the other handle image should do it for anyone wishing to copy it. If not, let me know and I can set it up with a camera in a long distance image.
The paper was all I had available and is in the convenient scale of 20 boxes to 3". Yes, 20 boxes to 3". That's 0.15"/box. I have no idea what the printer of this paper was thinking. It's not even metric. Where is Lee Valley (who sells good graph paper) when you need them? :D
Take care,
John
Re: Kenyon saw handle scanned on graph paper...
Fantastic!  Thanks, John
Neal in San Jose
And the strange scale is easy to deal with. Most copiers will adjust the scale up or down, so simply print the picture, measure what you got, and then make a copy at the appropriate correction. Likely your printer won't make an exact size print (mine doesn't), but if it does, all you have to do is make a copy at a 40% reduction, and Bob's your uncle. .15 divided by .6 is .25, which is a much easier scale to deal with. You may have to make several copies with small adjustments to get exactly what you want.
Thanks again for all of your effort!
Stephen Shepherd
Stephen Shepherd
John,
Do the horns show any signs of wear?
Stephen
Drawing is completed!
Dominic in Buck's County PA
Here you go John.
Kenyone back saw handle
I'm pretty confident about the scale. I checked it against the measurements you posted and it's within 0.003". How's THAT for accuracy! :D
Worked for me!
Neal in San Jose
Printed it out full size, measured the scale on the bottom (3 7/8"), did the math and it came out that I needed to multiply by 1.548. Turns out the copier here at work has a button for that exact multiplier. It is to expand an 8.5 x 11 to 11 x 17. Who knew? Anyway, made a copy of my original at that multiplier, and it is within my ability to read a scale!
Great work, thanks again.
Neal
Yo Dom, excellent!
Scott Burr in Ben Lomond CA
Could I ask that you send my a dxf? or .stp file? :) Please!?!
Well done Dom! :D
