We value your privacy.
I had time the other day to make some measurements of the Kenyon saw I recently acquired. The coarse overall numbers were taken using a tape measure. The smaller dimensions such as handle and spine thicknesses, were measured using an inch dial caliper. The blade thicknesses were taken using a 1" capacity B&S micrometer. If I have access to a larger micrometer, say a 3" capacity, + some small gage blocks, I can determine more fully if the blade is taper ground.
Some general observations:
There is a definite taper to the spine height, from 0.935" at the handle down to 0.885" at the toe.
Also, I was surprised that the screw-driver slot in the brass split nuts had a width of only ~0.022"! The slot of one nut is mangled, but the other is only a bit fouled up and clearly shows the very narrow driver slot.
Note - there is some indication of possible taper grinding in the (3) toe measurements taken. I'd really rather do a better job of measuring this if I can get (borrow?) a larger micrometer.
I still have to create a better image of the handle for Dominic to make an accurate handle pattern. Give me a few more days to come up with some suitable graph paper...
I layed a caliper on my pre-1900 Sikes & Son and the two dimensions are 'bout the same the whole length. maybe a bit thinner at the end but I don't think its enough to be intentional. Maybe it was an effort on Kenyon's part at "new & improved" ? Or another mystery like nibs ?
