New WoodChat!
ADVERTISE HERE - FREE TRIAL
Mounting strap hinges question
Scott Burr in Ben Lomond CA
Hi all, I just received the strap hinges for my blanket chest project. I've never used this type of hinge so I have a question. I know I need to mortise the hinge into the top of the chest so the lid will close properly.
Do I need to mortise the hinges into the back of the chest as well?
Would this provide more strength when the top is opened (kinda like a dovetail)?
Also what is the best way to complete the assembly, attach the hinges to the top first or the chest first then add the top?
Re: Mounting strap hinges question
David Miller from Iowa
Nice box -
Mortising in is optional. If you choose not, you just need some little bumpers on the lid to keep the gap parallel all around. I'd say those hinges contemplate not mortising but you can do it either way. I don't think it makes a material difference on strength. My kids would probably hyperextend it and rip it off either way (kidding).
I would put the hinges on the box first and the lid second - once you get them square on the chest, the lid will go on easily.
Warren in Lancaster, PA
I would not mortise the strap in the lid. It is a lot of work and it is not traditional. If the center of the hinge pin is behind the back of the rail, then you can mortise the hinge into the back rail almost to where the top of the strap is flush with the top of the rail. Leave the strap a little higher for clearance. You may have clearance problems with the lid and the back posts, because the posts are a little farther back than the back rail. You could chamfer the tops of the posts on the back to remedy this.
Thanks David, but in my neck of the woods...
I need the top to fit flat. Otherwise god only knows what might crawl in there. Especially in an old house like mine. No worries for the most part just daddy long legs and other small critters... :\
Hi Warren, there's no way in hell...
I'd inlay the hinges into the top. :b
Thanks for all your other suggestions/ knowledge about my undertaking.
You make sound easy as it should be, pretty much like I was thinking, but just needed to make sure before I'd do so. I don't want to screw the pooch on this one...
So to speak.
Re: Hi Warren, there's no way in hell...
Marv
Scott,
Is screwing the pooch a woodworking process that I'm not aware of? :\
I'm wondering how you are going to mark the holes for the strap that screws to the underside of the lid. Can you fit your carcass inside the box with a flashlight and have someone else center up the lid for you?
Here's a really dumb question.... shouldn't the bent part of the hinge be screwed to the outside of the box? This would allow the lid to open without interfering with anything.
Inquiring minds want to know. :D
Marv
Moses Yoder
Re: Strap
Moses Yoder
I think the strap goes on top of the lid not on the bottom ?
Hi Marv...
"Is screwing the pooch a woodworking process that I'm not aware of?"
Guess that all depends, have you ever screwed up a project right at the end so you had to start from scratch? If so you have...
As far as the hinge placement goes I've always seen them installed this way.
Have a look at PWW august 2009 #177 for an example. Here's another one:
Pam Niedermayer - Austin, TX
I think I must not completely understand your advice. If you don't mortise the hinges, how do you ever close the lid tightly, sufficiently tight to keep out vermin and/or insects?
Thanks,
Pam
Scott was asking about mortising the hinge into the lid versus mortising into the back rail. I am suggesting mortising the back rail to lower the hinge to where there is just a little clearance between the lid and the rail. I would leave the lid intact.
I see, thanks for clearing my mind. Would you mortise the rail sufficiently to encase the lid strap, too? Or just level with the rail strap?
Pam
I like it!
Marv
Great looking box, Scott....did you make that?
I like the color, but it needs to be a bit lighter. John Deere green isn't that dark.
With some heavy duty handles on the ends and wheels, it would make a good tool box. :)
Marv
I wish...
That chest is another wood workers. His name is Jeremy. He use to hang out here on at the pond. Sorry as you saw my chest is green but way to dark, no yellow added and is only semi gloss. Sorry for you my friend :b
As a toolbox well could make a good worm box :D
hmmm tool chest...
Jerome Bias
I'm still here, just been a bit busy and lurkingin the back gorund.
I never thought about adapting it to make a tool chest. I have been once again contemplating making one. It is actually a bit lighter than it looks on the web.
I found installing the hinges to be a bit of a pain also. I inset them into the rear rail as has been suggested. The funky part for me is attaching the silly things on to the lid. I first attach them to the trunk, then set up saw horses and such so that the lid is aligned to the chest and the rear edge of the lid lays to the rear of the hinge. (the horizontal part right before the barrel). Then I screw it down. Setting up the lid to the right Higth requires me to hold my mouth just right.
right now I am at hope plantation in Windsosr NC. Boy do they have some cool chests. I can't wait to start the next one.
By the way Where did you find your hinges. those suckers are expensive.
Jerome
Hi Jerome *LINK*
Sorry I got your name wrong. Thanks for chiming in on how you attached the hinges. I ordered mine from Nathans Forge. You are right, these are not cheep.
Nathans Forge
