Marking Gauge Till
David Miller from Iowa
Soliciting ideas for a marking gauge till/display. I have about 1/3 this many panel gauges as well. Thanks
Marking Gauge Till
Re: Marking Gauge Till
I suppose narrow shelves with slots cut in them, like a chisel or screwdriver rack, would be a good start. If I were doing it out here, I'd slant the shelf back to keep the gauges from coming off in earthquakes, but your quakes are pretty mild, at least until the New Madrid fault cuts loose again.
If you have access to sheet plastic, you could have clear shelves to show all the glory. If there's a plastic supply house anywhere near you, you might find some real bargains in their clearance bins.
A lot depends on whether you have more wall space or more floor space - if wall space is tight, some arrangement with hinged panels might be needed.
And I thought I had a lot with about eight gauges plus one panel gauge.
R.J.Whelan
David,
My guess is that you keep the marking tools you use elsewhere.
With that assumption I think I'd go for a straight display case(s) with glass doors - also assuming you have the wall space in your shop or "man-cave".
RJ (who isn't allowed to display tools in the house since moving to the retirement abode)
Brass Pins
Bob Hackett
I`m assuming at least some of these gauges have brass hardware involved so I`d just use brass pins set into a board to hold them in whatever arrangement you find pleasing.The brass pins would fit in with the brass hardware and block none of the view of the display.If you want to add sides and a sliding glass front or door to make it a shadow box then so much the better.
Hey David....
Rob Lee
... those heads slide back forth... you don't need a gauge for every discreet measurement!!
Wow... thats a lot of gauges...!
Cheers -
Rob
(adding nothing useful, as he stores his gauges in a small warehouse....)
Re: Every 1/64"
Moses Yoder
If you set a guage for every 1/64" from 0" to 6" you would have 384 gauges I think. Maybe he should plan for a bigger cabinet.
You're leaving out mortise and cutting gauges
Still more room needed.
And then there are wheel gauges, pencil gauges...
Re: You're leaving out mortise and cutting gauges
Bob Hackett
OK,here`s my amended suggestion;Size the boards/boxes to the sizes of oil paintings and arrange the gauges to mimic famous art pieces then hang them throughout the house as you would paintings.
Tell the wife you are blazing new trails and are tentatively calling your new approach "Utilitarian impressionistic cubism".
That should buy you all the wall space you need,till someone with a real art background comes thru the door and spills the beans to SWMBO.
I also suggest mounting the board/boxes on cleats so they can be easily moved when you are busted by the "art critic".
You're assuming in this...
that most mates aren't art critics.
Since I decided, long ago and with great joy, to spend my life with an artist, I could never get away with what Bob's suggesting.
But in my experience, most of us with significant others have at least a 50% chance of being with someone who considers her/himself to have a better artistic eye than we do.
Living with compromise
Bob Hackett
My wife is just happy if things aren`t on the floor for more than a few hours and if I keep tools out of the kitchen sink or off the counters during food preparation time then everything`s golden.
The microwave,oven and bathrooms are strictly off limits.I also get "the look" if she comes home and finds the Workmate set up on the porch or in the kitchen without a drop cloth under it.
My wife`s a gardener and most anything that approaches functional art and doesn`t encroach upon her space reserved for picture of the grandkids is OK as long as I take care of the yardwork and remember to ask her first.
"Art" surprises do not go over well with her,either indoors or out.
glh17
I didn't know marking gauges were like clamps.
Anything can be like clamps...
if you live in the right neighborhood.
The answer is simple. Trade them all for ...
... one of these ...
Re: The answer is simple. Trade them all for ...
R.J.Whelan
Derek,
You probably know the answer to this.
I wondered, at the time this originally appeared (as an April Fools spoof), if Rob actually built this, or if it's a pure computer fabrication.
I remember thinking that I hoped he had actually built this spoof as my wife and I have traded April Fools jokes back and forth for almost 40 years (current score: wife - 39; me - 1). We have spent considerable time and money over the years trying to top one another. After 40 years it's getting pretty hard to pull one off because we're both so suspicious of everything on that day that neither of us believes anything said by the other on April 1st.
RJ
AFAIK...
Scott Burr in Ben Lomond CA
They actually made some.
Rob Lee has said before that they do build them *LINK*
Sometimes - and I'm pretty sure that was true with this piece - it's a one-off. The only one I know of that they produced in quantity was the Precision Story Tape. As I recall, the manufacturer they used had a minimum order, so they've been offering them as a regular product until they run out.
http://www.leevalley.com/en/wood/page.aspx?p=65357&cat=1,43513
Re: Rob Lee has said before that they do build the
Pam Niedermayer - Austin, TX
Yeah, I bought one of the story sticks for kicks, but I've found it useful. Among other things, storage is compact compared to a real stick. However, I didn't have confidence that they'd always be for sale (yeah, I know, selffullfilling prophecy) and $5 plus shipping is a bit much for consumables. OTOH, if they were available locally (Maybe they are? Woodcraft?), I'd probably pick up 5 or 10 of them.
Pam
Wait for free shipping
Every three-four months or so.
Re: Wait for free shipping
My guess is that free shipping is only for great recessions. (:
Pam
Rob Lee
Hi Pam -
Bill's correct - it's every few months or so....it's not a recession thing...
Cheers -
Rob
Rob Lee
Hi R.J. -
The April Fools day tools are all real. We just started working on the selection/design for April 2011 at yesterdays R&D meeting.
We do have a set of internal "rules" for the project (and it's booked like a normal project):
1) It has to be credible
2) It has to work the way we say it does
3) We have to make at least one actual tool (not a mock-up)
While we do take some liberties with the writing style in the product description - we can't just make things up.
The magnetic tool belt, for eaxample, really does hold more than 500 pounds... the fellow shown wearing it is our main plane designer, and if you look carefully - the tools stuck on the belt are worth well in excess of $10,000 .
Cheers -
Rob
That's cool, thanks, Rob, never saw it until a couple of months ago.
Pam
