New WoodChat!
Hand Plane Refurbish Question
Thomas Norton
I got my Stanley #5 via ebay and have disasembled and cleaned it. I am in the process of lapping the bottom. My question is to what grit do you guys go with this process?
Thanks
Re: Hand Plane Refurbish Question
Bob Hackett
I like to start at about 220.That way if the sole is pretty much flat you don`t have to chase coarse scratches.If it`s not flat then the bright patches will tell you where and how bad the sole really is and you can make an assessment as to starting grit from there.
No sense beating up your new plane if it intends to co-operate right from the start. :)
Did you test it?
I've only ever tested one of my No. 5 planes, and it came out at 0.002" out of flat, in the right direction (slightly concave). It wouldn't be hard for me to make that worse in the course of trying to flatten it.
Moses Yoder
Moses Yoder
It is important to lap the plane with the frog attached and an iron locked down with the lever cap but retracted so it won't hit the grit you use to lap the bottom. Installing an iron will put pressure on the sole. Often times there is a small bump right behind the mouth that will prevent the sole from making proper contact, and sometimes there is a convex gap infront of the mouth that will prevent the plane from taking fine cuts without tearout. I would install the iron then look at the sole with a straight edge, hold the plane up to a light, and see how bad the sole is. I figure the sole is going to get some scratches from use anyway so I usually only lap it to about 220. You can go to 320 or 400 and probably not notice any improvement in performance. If you have a bit to remove I start with 80 grit but you could just as well start coarser if you have the paper.
Thomas Norton
I found some 90 grit Lapping Compound in my shop. So I have sarted with this. Just a small area by the mouth that has not succumbed to my work! Will move on to other grits as time permits.
