New WoodChat!
Hand tools in remodeling (long)
One of my current projects is conversion of a shed in the driveway, slightly uphill from the house, to a workshop - bringing in power, insulation, finish walls, bringing up to code, etc. We started this shed some years back, and then our son needed somewhere to store stuff for a while, and he filled it up; which kind of got in the way of completion. But his stuff is out now, and we decided to step up from storage to higher uses.
One of the changes to bring it to code is to close off the doorway facing the driveway, because a code doorway has at least a 3 by 3 foot landing outside - which would reach into the driveway, not workable (it gives us more wall space inside too). That, in turn, means running siding over the closed-up doorway opening, not something I knew I'd be doing when I built the shed. Our siding is shiplapped channel rustic (see first photo below for a sample), rather pricey, and I saved a little money on the last (top) board by using a regular 1x6 and cutting the shiplap (with an electric router; sorry). Since there was no siding at the doorway, I didn't cut the shiplap over the doorway...but now, there'll be siding there, and I needed to cut in the shiplap rabbet somehow. I really didn't want to remove the board - lots of nails to pull, much damage to the boards, etc. - so I decided to cut it in place.
This is the lower-edge shiplap, so the rabbet is inside the board, against the building. There are probably power tools of some kind that can cut a 3/8" by 3/8" rabbet flush against a building, 5" from the edge of the sheathing; but I don't own them, so it was hand tool time.
Here are all but one of the tools (the last one gets featured in its own picture, later):
The marking gauge scribed the edge of the rabbet. The 3/8" chisel (small one) was then used to strike down and make chips; I found it wasn't a very effective paring chisel, partly because it was too short for clearance against the sheathing, so I brought in the mortise chisel. Alas, this is a 5/16" chisel, and I needed help clearing that last 1/16" of wood - thus the Murphy mill knife (great tool, by the way. If you ever find one, snag it; Lee Valley sells replacement blades). The mallet is, well, a Horrible Fright deadblow mallet.
Here's the scene of the crime as I started. The rabbet needs to be cut in the board running across the top of the doorway, visible above the sheathing and below the frieze board.
You can see here the scribe line on the board:
I forgot to take a picture of the work after the initial chiseling, but you can see in this picture evidence of the 3/8" chisel strikes (let me comment that striking up over your head every 1/2" or so 72 times is not a lot of fun):
And, after some paring with the mortise chisel, trimming with the mill knife, re-paring with the mortise chisel, repeat several times, we have a rabbet. I am very grateful that this won't be visible in the completed building - the run of siding right below will tuck up in here, hiding the work.
When I worked as a gas pump jockey* in my youth, we all carried tire depth gauges in our pockets, so we could point out to customers when their tires had worn thin, thus making a tire sale and earning points (but no extra money) from our bosses. I found the one pictured below in my dad's toolbox from the station, so it might have been the one I carried; or not. If you happen to see one of these at a garage sale, grab it; it's a great tool for gauging depths of holes/rabbets/etc., because it's compact and will fit in tight spaces, and is direct-reading (in 32nds; ignore this if you work in metric, unless you find a metric version of this).
*For the benefit of those under 30, gas stations used to employ people, mainly high school students, who, when you pulled into the gas station, would come out and pump your gasoline. Good ones would also wash your windshield and check your oil. Great ones would wash your back window, side mirror, and, if you rolled up your driver's side window, that window; and could do all that in the time it took for the pump to fill the tank, if you were driving an American car. World-class pump jockeys could run several cars at a time on different pumps, while cleaning windshields, etc. It was a fine and honorable job that payed minimum wage, like so many fine and honorable jobs back then. Minimum wage, by the way, was $1.65 when I pumped gas; gasoline cost 35 cents/gallon.
Re: Hand tools in remodeling (long)
Bruce, a MN Galoot
I learned carpentry, both framing and finish, from my dad. I'm generally pretty persnickety by nature, and that used to both amuse and frustrate Dad, especially when we were framing. I'd be lining up studs, etc., to the nth degree and he'd remind me we weren't "building a piano." However, when we moved inside and he started teaching me finish carpentry, he told me "NOW we're building a piano."
There's a time and place for stuff that will never see the light of day, and, Bill, you did good.
wilbur
"For the benefit of those under 30, gas stations used to employ people, mainly high school students, who, when you pulled into the gas station, would come out and pump your gasoline."
In New Jersey, there is no option to pump your own gas. All gas stations are full service here. My worry is that what happened to one of my friends who grew up in NJ will happen to one of my boys. My friend, who was living in Chicago at the time, went out on a date. He needed to stop for gas, cooly pulled up to a gas station, and sat there, waiting for the full service that was not coming. Luckily, his date got beyond that initial snafu, and now they are married, with a couple of girls who play with my boys all the time.
They went away in the 1970s in California. I have, at times, wondered, in a chicken/egg sort of way, whether gas stations in this area stopped having mechanics as part of the station, something else that happened during that period, because there were no longer pump jockeys to spot problems with cars, thus leading to work for the mechanic; or whether the loss of tire-changing and other minor mechanical jobs that the pump jockeys could do led to their being financially unsupportable.
Either way, it's yet another entry-level job lost. I don't know what high school kids do for work now.
