Re: WOW ! . . .
scott grandstaff
So how do we start getting the old veneer off ?
You don't, any time you can avoid it.
You repair what you have if at all possible. And it is practically always possible in the condition you found them in.
Taking all the veneer off is just like taking all the old finish off a piece of furniture down to bare wood. If you have to, you have to, but otherwise its always, always, better (and 100 times easier) to restore what you already have. The concept of "skinning" work was invented by people who sell supplies for the job. It is never easier or quicker, believe me.
The job of restoration is quite challenging enough, thank you.
Veneer repairs you can learn to do for almost free. It takes little more than a supply of scrap veneer, clamps, cauls and tape, and.... time.
Find matching or as close as you can get veneer. Line up the grain pattern carefully, cut your patch oversized and avoid straight lines like the plague. A straight line demands your attention like neon. Curves blend.
Overlay your curving irregular parch and trace around it. Take sharp knives, chisels and scrapers and remove the old.
Pad your replacement piece with a "caul" or scrap wood, wax paper inbetween and clamp it down, using ordinary glue. If you can't clamp it, lead bricks or very heavy weights of any kind will do.
Next day scrape it clean and blend with a little stain and/or artists oil colors and after a few tries color matching it will just disappear before your eyes.
With your top tore up that bad now, you are going to have scrape all the old veneer off the top and start over there.
Sharpen your scrapers often and go to work. I like to use 4 or 5 scrapers, using each one until the edges are gone and then re-sharpening the whole batch at once.
Do not mess with the rest though, you can still save that!
Veneering full panels means either, buy an expensive vacuum press (guaranteed success rate, but it better be at hundreds of dollars cost, and decide carefully if you are going to go into veneering full time or else you have foolishly wasted a lot of money for another dust covered box in the corner of your shop),
or begin to suffer contact cement (always hated it myself but I have seen good work done with it). You can't get the "good" contact cement anymore and even the good stuff was always lousy, IMO.
But again, I know a couple guys who are good with it, so its possible.
or try the iron-on veneer (Jury is still out). It was a popular fad once. I don't hear about it anymore though, so that makes me uncertain.
Or........ master the ancient art of hot glue hammer veneering.
This is the fully traditional way. A learning curve for sure, but not so expensive to start.
There are 88 million websites already established on veneering. Take a Google stroll through any number of them. But watch out for the dozens of heavy sales pitch sites telling you how easy life is, if you only BUY something. Something they conveniently have for sale at top dollar, by the way.
yours Scott
