New WoodChat!
Nice Chisel.
Nice Chisel.
Nice Chisel.
James Watriss
I spent a few hours tonight clearing dirt, grass, and other debris out of an interesting slab of lumber that I had kicking around in the lumber bin.
Slab table will be in the works very soon.
Re: Nice Chisel.
Re: Nice Chisel.
James Watriss
Another shot
Re: Nice Chisel.
Nice wood, too
and I take it that was a driveby of an LN chisel?
How do you ensure that you've got no live colonies of critters in a slab like that? If I had a slab in storage with those kinds of nooks and crannies, I'd be raising spiders, at the least, in it.
Re: Nice Chisel.
Re: Nice wood, too
James Watriss
Wasn't really intended as a driveby, I just thought it was a funny picture.
It's true that clearing out all the debris has now left it open for occupancy by one of the shop spiders. But after 4 years, I'm pretty sure there's nothing new growing in there at least.
Re: Nice Chisel.
Got a coffee grinder?
Bob Hackett
One of the best ways to deal with bug tracks,voids and bark inclusions I have worked with is to use one of those small electric personal coffee grinders to process what ever material you choose to the consistency you need and then use it as a filler to mix with the epoxy and then pack into the spaces.Any touch ups or contrasts you need or want to fill can be done with the dry powdered material and thin CA glue.
For filler I have used sawdust,bark and surprisingly,coffee ground to whatever degree looks good in place.Chisel some grooves and fill some test pieces before you commit the project though for best results.
Both the epoxy and the CA patches almost disappear with an oil finish and a finish coat of wax.
Hope this has been of help.
Re: Nice Chisel.
Re: Got a coffee grinder?
James Watriss
Given the size and scope of the bug tracks, and the amount of the board they've taken over, I'm actually considering using a clear epoxy or an acrylic casting compound. I did that once on a broken out knot in a table top, to surprisingly good effect.
Once everything wets down, as long as the filler is really clear, it actually shows off a lot more of what's going on. And since there are holes that do go all the way through the material, I think that some of it will actually be lit up from inside by ambient light coming in through the bottom.
Small inclusions and tracks look better when they're filled. But I think something like this either has to be removed completely, or turned into a design element.
Re: Nice Chisel.
David Barnett
Save those stale Vienna Roast beans *LINK*
David Barnett
Coffee as a pigment and filler has been around for a long time. I've roasted to between Big City Plus and Vienna to sweat out the oil, ground to powder, added colloidal silica flour for body and structure, and combined with pourable water-clear acrylic (you can also use epoxy and polyester) to form a versatile casting resin. Works with wood -- great looking irregular stripe on a split plank conference table top -- is turnable and even carvable and bendable for costume jewelry. Color is somewhere between African blackwood and ebony. I've also used it in encaustic.
CafeGraphia
