New WoodChat!
Foley Retoother Carrier gauge
Dominic in Buck's County PA
This tools MAKES hand tools. So I'm going to go out on a limb and ask this question here.
Back about 2 weeks ago I picked up a pretty much complete Foley Retoother. This past weekend I finally got around to getting it set up and ready to go. I mounted it to a piece of plywood so I could more easily more it around. This base also made it easier for me to secure it to my workbench via some holdfasts.
So I'm getting ready to try out adding teeth to a likely looking piece of 0.025" 1095 spring steel when it hits me. I don't know how far I need to have the saw plate project above the carrier bar. So off to the manual I go. And what do I find? They are using a little jig called a "Carrier Gauge" (P/N: 3249149) to help set this distance. And guess what I don't have....
Does anyone have or use this gauge for your Foley Retoother? This is shown on figure 15, page 14 of the Foley Retoother manual.
If anyone does have it, could I get some dimensions and a photo (with a scale in the field of view so I can take dimensions from it)? Any information I gather will be shared with the group here.
(BTW, I sent PMs out to some of you concerning this already. But I figured that this broadcast request might flush out some other Foley users. I'd go to OWWM but I'm still waiting for a confirmation email saying I'm cleared to post questions there)
Thanks!
See ya around,
Dominic
Re: Foley Retoother Carrier gauge
A Bit Complex
David Miller from Iowa
I have the "carrier" you seek and can help you out. However, I do not have extras Of the retoothing bars - you need one for every size tooth you hope to punch. The carrier holds the saw and then you attach the retoothing bar (i. e., if you wan a 10 TPI you need the 10 TPI bar - these are really hard to find.
Further, this is part of a set - the tool you have punches the teeth and then you take it over to the Foley automatic filer - without removing it from the retoothing gauge - the filer is another big machine that weighs 150+ pounds) and file it. You can use the saw after punching the teeth, but they really need filed to perform. Then you set them - I had a foley setter but I scrapped it - it kept busting the teeth on my old bishops. I just use a plier set and do it by hand.
email me offline for more dlmiller90@gmail.com
Dominic in Bucks County PA
Re: A Bit Complex
Actually I have 5 carrier bars and a bunch of the ratchet bars (from 4tpi up to 14). But I'm on the lookout for the 15 and 16 tpi ratchet bars if ya got em' and want to sell!
What I'm looking for is called a "carrier gauge" and is shown in Figure 15 on page 14 of the Foley retoother manual. It's used to help you set the amount that the saw plate projects past the edge of the carrier bar. Certain size teeth require more projection while smaller ones require less.
in my original post I included a link that'll take you tight to the online manual.
Re: A Bit Complex
Andy Lincoln,in Dearborn,MI
Dom,
This may sound crazy but could you try copying the picture ,scaling it and redrawing in CAD?
I would hate for a small part to hold you up from making my next new handsaw!! ;)
Andy
Re: A Bit Complex
Dominic in Buck's County Pa
Yeah, I'm working on that as we speak. I actually brought the PDF up, captured the image, imported it into AutoCad and have traced it out. But having a REAL width will allow me to scale what I have traced to the correct size
Alan DuBoff
3/4", you can just use a piece of 3/4" wood and let the saw plate drop down to the table, making it 3/4" extended above the carrier.
Hand vs machine
Bob Hackett
As someone who has used both machine punched saws and hand file retoothed saws my preference is to use a hand filed one,especially if the saw is a coarser rip.
The reason is they seem to work more smoothly for me.I attribute this to the slight variations you get from hand filing the teeth in.There is also much less chance of breaking a tooth or slightly bending the edge of the saw blank in the direction the teeth are being punched.
Even though machine sharpening was cheaper all the joiners in the yacht yards I worked in sent their saws out to be hand filed or did it themselves.
Don`t know what your skill level is Dom but the more you file the better and more accurate you become.I look at retoothing as an excellent way to build muscle memory.
I keep telling myself that as I look at the new blank clamped in the vise and wait for the zen to arrive. ;)
Re: Hand vs machine
As of this moment I'm hand filing saws. And due to room restrictions in the shop I really don't have any intention of getting an Foley Saw Filer.
The tool I just got is a Retoother. That just cuts new teeth into the saw plate. It's a lot easier than having to refile them, and IMHO more accurate. After that I will sharpen and set the teeth by hand. :D
Thanks Alan. I'm going to try that out on a piece of scrap spring steel.
I'll tell you how I make out.
An aside....
Marv
Dom,
A retoother that has a sharp die and punch will do a great fast job of retoothing, especially those bigger teeth. Emphasis on "sharp die and Punch". The punch must be such that it cuts the metal, not push it through the die. If it is dull it will warp the blade.
Here's the "aside"...
You are probably filing every other tooth from one end of the blade to the other, then turning the saw and filing the other teeth in the opposite direction. Try this....don't turn the blade and don't flip the rake angle block on your file. Leave the saw in the same position in your vise, file from right to left, change your fleam angle to the opposite direction and file from left to right, leaving the saw in place. This can be done on both rip and crosscut. I find that this method works great on teeth up to 8PPI. For larger teeth I do turn the blade due to too much screeching and vibration of the file.
You might try contacting Leif Hanson regarding your retoother needs. He has one and might have some answers for you. Knowing him as I do, he'll probably give you some good hints as to how you can easily make the part you need. He's a pretty clever dude.
Marv
Re: An aside....
Marv,
You wrote:
"You are probably filing every other tooth from one end of the blade to the other, then turning the saw and filing the other teeth in the opposite direction. Try this....don't turn the blade and don't flip the rake angle block on your file. Leave the saw in the same position in your vise, file from right to left, change your fleam angle to the opposite direction and file from left to right, leaving the saw in place. This can be done on both rip and crosscut. I find that this method works great on teeth up to 8PPI. For larger teeth I do turn the blade due to too much screeching and vibration of the file."
Cool! That's exactly what I have been doing! But I have to admit, it's more out of sheer laziness that I don't flip the blade unless I can avoid it. :D
And I've already been in contact with Leif. he sent me a manual page from a Filer that shows the old style Carrier Gauge used on that. And from what I can gather, it sets the blade projection the same for any size tooth. That goes along with what Alan was saying.
