New WoodChat!
Buckeye post drill value and question
David Miller from Iowa
I have a chance to buy a Buckeye post (or beam) drill - the kind you sit on, except this one is all cast iron. It is pretty cool - has 2 speeds that you change by pulling the head off and flipping it over. The pictures is from Worth Point - if anyone has a subscription, I would appreciate a value look up.
On the drill I am looking at, one of the crank arms is bent in - literally 1" bent in with a little twist - still works fine. There is no way the cast iron could have bent this much and it must have been cast that way - can anyone tell me if the arms were symmetrical on this one?
Thanks
Re: Buckeye post drill value and question
Not only is it not worth anything, it's a positive danger to your and your neighborhood. It will cause crops to fail, woodpeckers will invade your house and peck holes in the trim, children will run screaming when they see you. The best thing to do is buy it quickly and send it, oh, 1500 miles or so west. For some reason, the danger is reduced when it's roughly 10 miles from the Pacific ocean. I can store it for you, and won't even charge a storage fee.
