New WoodChat!
Odd Bit Brace Chuck - holds flat bits not square
David Miller from Iowa
Picked this up at a sale yesterday - Was going to pass it up because of damage, but I glimpsed the odd chuck hole - it is 5/8" long and 1/4" wide. Have you seen this or even any bits for this? What gives?
Re: Odd Bit Brace Chuck - holds flat bits not square
Re: Odd Bit Brace Chuck 2nd picture
Here is the whole thing
I have a similar looking brace, though not with the added rust feature that yours has (I'm jealous), but it takes conventional tapered square bits.
Yours may be the product of someone's ingenious plan to revolutionize the auger bit industry, yet another failed business endeavor.
I know old taps sometimes had flats instead of the squared-off shanks of modern taps, and, if you look at the design of most tap wrenches, you'll realize (as I did AFTER passing on a whole bunch of flat-shanked taps) that you could put such a tap in the wrench. But a brace is not the right tool for use with a tap - I think it would be hard to keep the force centered properly.
Dale Warder
David, I obtained a small group of bits with a flat tapered shank which look like they would fit such a chuck. These were in a box lot of junk I purchased a couple of years ago. As the bits were obviously produced with this shank, such a chuck must have been available at one time. Tomorrow I will try to locate them and see if there is any further information.
Dale
Stephen Shepherd
Stephen Shepherd
David,
Flat tang blades were common in the 18th century and earlier and the braces were made to hold them. Some were permanently fastened into wooden chucks that fits wooden braces. Yours is probably a late 18th or early 19th century version. I have one that holds both flat tang and square tapered bits that probably dates a bit later than yours. Nice find. Now you need to make a split turned handle and get some flat tanged bits.
Stephen
Michael
Michael
David,
I have found several braces like yours at flea markets here in Germany. I don't know if they were German or French or just "continental." I've found some older style shell bits that use the flat shank. I've also found one brace with a combo chuck that will accept square or flat tangs.
