New WoodChat!
Buffing wheel station V.2
James Watriss
So this afternoon I spent some time tweaking the setup, as chronicled here.
I was told that felt wheels, being harder, are less likely to round over an edge. And after reversing the grinder motor so that it's basically running backwards, the idea is to use the tool rest to present the tool to the wheel at a reliable angle.
So far so good, figured I'd share.
Re: Buffing wheel station V.2
"here"
James Watriss
My HTML is rusty. So much for the link.
"Here":
http://jameswatriss.blogspot.com/2010/09/buffing-wheel-part-ii.html
You need a new jig.
Scott Burr in Ben Lomond CA
James,
Ditch the wimpy Jig. Go for a Wolverine. No comparison. I personally can't stand my LV rest. Yea, I splet it correctly :b
Bruce, a MN Galoot
this is about sanding belts, not your buffing setup. BTW, I think I'll give your buffing arrangement a try.
Knife makers use very fine grits in stock removal methods of making blades. One knife maker I know uses 600 grit SiC belts for final polishing of his pattern welded blades with very fine results.
Here's one source that has belts up to 6 X 48", 400 grit belts in AOX that could fit the bill. If there is one source, there are others.
http://ajh-knives.com/supplier-2.html#abrasive
Re: You need a new jig.
James Watriss
I have a wolverine, and for using a regular bench grinding, it's unsurpassed.
But for using on a buffing wheel that's soft and running backwards, that seems like it would be overkill...
Even for you. :)
Buffing and power honing
Bob Hackett
The reason I was asking previously about the lathe was that rather than have multiple dedicated grinders around the shop one of my friends showed me a very neat trick that allows you to make max use of your lathe while trimming your sharpening tool inventory.
He made a mandrel for his lathe that allows him to gang up a series of wheels that he turned to custom fit his most used tools,like those multi-wheel hones the carvers use and pay big bucks for.
Using the lathe as a drive allows him infinitely variable speed and reverse at the flip of a switch. He turns the wheels out of whatever is appropriate for the task,MDF,masonite,marine grade plywood,maple discs,etc and loads them with the appropriate abrasive.When not in use the mandrel is easily stored in the overhead.The lathe tool rest allows for a more flexible base for jigs and fixtures and is several orders of magnitude more adjustable and adaptable than any grinder tool rest that I`ve come across so far.
The light is already at hand and the lathe is already at a height that allows comfortable and natural stance at the machine while allowing excellent field of vision.The weight of the ballasted lathe makes the set up far more stable than even a heavy weight industrial grinder and if you have a sliding headstock or bowl lathe you can even use it as a disc sander with a custom made disc of the size you would dream about getting from a pattern maker`s auction.
In summary,with a little thought and work that lathe that stands mostly unused in the corner of the shop can be made to perform just about any function that requires spinning something.Haul it out and make it earn it`s floor space!You may end up being able to sell those extra grinders,rests and other redundant equipment for enough cash to get those high quality chisels you lusted over but thought you could never afford.
One lathe and mandrel is more in keeping with your 100 item philosophy than 3-4 grinders and their support tooling now isn`t it? :)
Re: Buffing and power honing
James Watriss
That sounds AWESOME.
But I want pictures. And more of a story about how he made the mandrel.
I'm nowhere near being a "100 things" kind of guy. But it would be nice to trim some of the redundancy around the shop.
For now, it's pretty easy to fit a 6" grinder into a space that's close enough to the bench to be readily available when I'm doing benchwork...
Relax
David Miller from Iowa
James - I understand your rationale for the motor reversal tool rest thing. But the way I see it, buffing wheels don't (perhaps shouldn't?) need that kind of support.
I know everyone does this differently (and I agree we are all right as long as the cutter works well) but I have the mantra that grinding needs jigs/rests and buffing is freehand. I have never buffed a plane cutter for more than 10 seconds on the back and more than 3 seconds on on front. However, I salute you if you can get even shavings however you do it.
I used to obsess about stuff like this until I saw a David Charlesworth video and his style of more planing and less honing really resonated with me. My current strategy is to spend the time I used to obsess on the cutter edge looking for better stock - even a mediocre cutter will do fine on outstanding wood, but the walls start closing in one me if I have tricky stock and start fretting about the edge too much.
Regards, David
Good call
James Watriss
You raise a really critical point.
Mostly, I'm just looking to keep things sharp enough to keep working. I am aware of my knee-jerk tendency to overthink everything, but it generally works out.
But the focus on workable stock is a lot more relevant than the regular ramblings in here about plane setup and shiny new toys.
