New WoodChat!
retrofitting Norris style adjuster
david in indy
I built a dovetailed infill plane a couple of years ago using the Shephard kit. At the time, I had read David Charlesworth's account in Furniture and Cabinet Maker of his doing the same, but he added a Norris style adjuster that was not part of the kit. Anyone have any idea as to whether it's reasonably possible for me to do that now and, if so, a source for the adjuster? Thanks.
Re: retrofitting Norris style adjuster
Neal in San Jose
The where is the easy part: St. James Bay Tool co. (www.stjamesbaytoolco.com) Finding it on his web site is hard. I gave up after a couple of minutes. It may be there, but you might have to call him. Nice guy, good products.
Jim in Burlington Ont.
ebay
I bought several shepherd planes from e-bay off of the seller jurassicjockey apparently he had bought up the rest of the stock.
Now you know where to find them, I'll ask why?
Scott Burr in Ben Lomond CA
I have 3 Norris planes and 2 other infills with out adjusters. The Norris adjusters are a PITA as far as I'm concerned. So much so that I'll reach for a non adjustable plane first.
That said, installing a adjuster after the plane is built will be tricky if not impossible, unless you remove the lever cap. I've never done it but looking at my planes it seems extremely difficult or like I said near impossible.
Re: Now you know where to find them, I'll ask why?
david in indy
I've never felt comfortable with my ability to set the blade where it needs to be on this plane. I have found myself frustrated and reaching for one of my other planes. I may not have given it enough time. Now that I have confirmed that it would be nearly impossible to add an adjuster, maybe I'll give it another chance or possibly sell it to someone who will. Thanks.
Dissenting opinions
James Watriss
I can understand your issues. My first suggestion is to set the plane up by putting the iron in it, barely loose, but still movable by hand, with the plane on a flat surface. Then crank down on the lever cap. My second suggestion is to get a smaller hammer to make your adjustments. It's easier to make finer adjustments that way. And if your small taps send the iron wildly out from where you want it, maybe tighten the lever cap more, to make it harder to move the blade.
There's an entry on the Sauer and Steiner blog about how Konrad thinks that one reason that the old Norris adjusters are typically worn to the point of being damaged is that people don't know how to use them... it's necessary to loosen the lever cap first, then make the adjustment, and then re-tighten everything. Not loosening the cap means excessive force required to adjust the iron. Moral of the story is that it's not like running a stanley plane... it's something that requires a lot more mental presence.
it may be worth taking another look at your plane to make sure that everything is in proper alignment, and make sure the lever cap isn't pinching on one side or something like that. I have an old Mathieson that's basically been dead to me for years, because of just this issue. I've even debated pulling the lever cap out to either fix the plane or put the lever cap into my Lie-Nielsen. Jury's still out.
Lever cap blues
Bob Hackett
Since this is a Shepard plane and not an antique why not just remove the lever cap and do the work you want then replace the lever cap and this time go with spring loaded shouldered pins to hold it in place yet make it easily removable in the future?
Gary Hodgin
Here is St. James Bay Tool's address.
www.stjamesbaytoolco.com/
Gary Hodgin
Neil,
Sorry, I misread your message. I thought you were looking for the web site, but now see you included the same url in your reply.
gary
craigd
Re: Dissenting opinions
craigd
I also use James' method to set the iron on my infills - I don't typically use a hammer to adjust (unless it has a wedge). Set the plane on a board, tighten the cap screw while lightly pushing the iron into the board. I even leave the screw loose enough than I can move the iron laterally, don't need no steeking lateral lever! Haven't had any issues with the depth changing on either the bevel down or bevel up.
Craig
wayne anderson
IMHO, a Norris adjuster is truly a worthless PITA, as was said earlier. That said, if you really want to install one, you will have to remove the lever cap, and route out a huge pocket for it. You can probably go on Konrad's or Karl's site and see what this pocket looks like. A milling machine would be a big help, or possibly a router and jig. Either way, it is going to be a major job that requires high accuracy if you want it done right. -w
Adding an adjuster.
barryavbeach
Just to give the contrary opinion. I have about a half dozen infill smoothers without adjusters ( Pre war Norris's, Spiers, Mathiesons, ) and a post war Norris with an adjuster, and a SJBTC panel plane and smoother. I built the SJBTC planes before I started acquiring infills and I built the panel plane first without an adjuster. A few years later, I ordered the smoothing plane with the adjuster, once I used it I was hooked and went back an adapted the panel to accept an adjuster right away. Once you take off the lever cap it is pretty easy - I just used a saw and a chisel. I also later bought a very rough Spiers, and adapted that to take an adjuster. I have the Ray Isles in one, the SJBTC in another, and made my own for the third. While I hear a number of complaints about the Norris style adjuster, ask someone to show you how to retract the iron a few thousands without an adjuster. While those with skills might be able to do that, I can't - which is why I use adjusters. I don't use them for lateral, just a tap on the side of the iron, but to retract it a little, nothing beats an adjuster. I agree that the post Norris is way too coarse an adjuster, but SJBTC and Ray Isles both used around 40 tpi - which gives you very fine adjustment, and no where near the slack of the Stanley adjuster. If you were going to make your own, look at the LV adjuster, it uses a pin instead of a socket for the cap iron screw, which I think is great idea - you don't have to worry about the screw head to socket fit.
